by JAVYPRO. 12/11/18 11:16 PM
The engine build continues...
by DRTDEVL. 12/11/18 01:54 PM
Which KYB for Gen 1 V6?
by JARED. 12/11/18 01:49 AM
Old Man Emu Lift Installation
by Snowtoy. 12/10/18 10:46 PM
88 Raider KM145 tranny
by DRTDEVL. 12/09/18 02:47 PM
by Bevoman. 12/08/18 08:00 PM
by JARED. 12/08/18 12:07 PM
Tire/Wheel pics
0 registered members (), 122 guests, and 2 spiders.
Topics137,948
Posts1,079,802
Members14,849
Zerk Fittings #433450
04/12/04 02:48 AM
04/12/04 02:48 AM
A
Anonymous OP
Do 1995 Montero's have "zerk fittings" on them? There will be a zerk fitting on all tie rods and ball joints in the newer car's have not seen them on my Monty.. http://www.my-gmc.com/Zerk-2.jpg
Re: Zerk Fittings #433451
04/12/04 07:10 AM
04/12/04 07:10 AM
bretwalda  Offline
Milwaukee WI
There are no zerks on the Monty. All mitsu parts are self lubricating though I occasionally spray mine with PAM.
<img src="/forums/images/graemlins/drunk.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
concreteprinter.com
Re: Zerk Fittings [Re: bretwalda] #433452
04/12/04 08:46 AM
04/12/04 08:46 AM
stony-man  Offline
Ohio - Northeast/Centralish *****
Oh come on now Bret, you KNOW that in the weather conditions in our part of the world mean that Crisco works MUCH better. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Zerk Fittings #433453
04/12/04 10:50 PM
04/12/04 10:50 PM
off-roader  Offline
Bay Area, CA *****
HPI,
I'm sure there are copious numbers of zirk fittings under your 95. Have you looked? You could probably answer your question with a couple of minutes worth of inspection since nobody has answered it who has a 95.
Not sure which components have them but they are certainly there. I've got over a dozen on my 90.
Ray
Off Roader
96SR (3.15:1 xcase, 35's)
96SR Build Up Thread
Old web page
Old web page
Re: Zerk Fittings [Re: off-roader] #433454
04/13/04 01:26 AM
04/13/04 01:26 AM
A
Anonymous OP
There are not many zerk fittings on a 95 Montero, and these are found on the front suspension, steering and prop shafts. They are located as follows:
Rear of Lower Control Arm - Ball Joint (L & R)
Top of Upper Control Arm - Ball Joint (L & R)
Tie Rod (Outer) - Ball Joint (L & R)
Tie Rod (Inner) - Ball Joint (L & R)
Pitman Arm
Probably Idler Arm as well (not 100% sure)
Front Prop Shaft (Front & Rear U-Joint)
Rear Prop Shaft (Front & Rear U-Joint)
To do the front suspension, steering & front prop shaft, raise the front end & support securely on axle-stands. Remove both front wheels and skid plate, then all the fittings should be easy to get at. You will find you need to rotate the front prop shaft by hand to get to the fittings in the U-joints. Same applies to the rear prop shaft, but you will only need to lift one wheel off the ground - support the rear on an axle-stand for safety. There is no need to remove either of the rear wheels.
Cheers <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Zerk Fittings #433455
04/13/04 02:22 AM
04/13/04 02:22 AM
A
Anonymous OP
Thanks alot. I will head out to Auto Zone this weekend and get a grease gun w/ some synthetic grease along w/ it.(Im a synthetic whore..:)!)
Page Time: 0.009s Queries: 15 (0.003s) Memory: 1.0094 MB (Peak: 1.1146 MB) Zlib disabled. Server Time: 2018-12-14 02:49:43 UTC
