60
My Sportage grunts and groans
#474009
07/08/04 09:03 PM
When I turn the steering wheel and hit any irregularity in the road, the car usually grunts and groans in the front. I suspect worn struts are causing the noises. Then again, if a car's age is reckoned like a dog's age (1 year = 7 years), then my '96 is about as old as I am. So maybe it's natural!
Paw-paw Don, y'all .
Re: My Sportage grunts and groans
[Re: DSHornet]
#474010
07/08/04 09:30 PM
very possible it could be a multitude of things. check everything that should have grease, bushings, bearings, balljoints and anything that moves when you turn. it will take a while, but when you quit hearing it, you have replaced enough parts.
i'm guessing either balljoints, TRE's, Idler Arm or steering box.
[Re: Dave Scott]
#474011
07/08/04 09:37 PM
I'm pretty sure I have somewhat the same problem and I think I narrowed it down to the Idler arm assembly.
[Re: tlab]
#474012
07/08/04 09:52 PM
Kia Moderator Emeritus
Bad lower ball joints. Sounds like the noises mine was making at one time. <img src="/forums/images/graemlins/smile.gif" alt="" />
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: tlab]
#474013
07/09/04 06:02 PM
I'm pretty sure I have somewhat the same problem and I think I narrowed it down to the Idler arm assembly. speaking of............ you still want it? it's just sitting here.......
[Re: Dave Scott]
#474014
07/09/04 08:59 PM
Yes, you were supposed to get back to me with a quote on shipping ....... Remember. But yes, I will take the stuff I asked about. If you have one I also need the drop link bolt/ball joint for the pass side sway bar. My ball joint broke off and I can't reattach the sway bar.
[Re: tlab]
#474015
07/09/04 09:23 PM
hmmm..... i'm sorry, i don't remember that, no problem, i will do and get back to you.
on the sway-bar ball joint- sorry, i ran my sway-bar loosened up for a while and it destroyed the threads on it.
