Gen1 2.6L alternator upgrade
by rascott. 09/19/18 05:27 AM
WTB: Mitsubishi Gen1 seatbelt
fuel tank/ separator tanks
by rxinhed. 09/06/18 04:00 AM
1989 LWB A/T Temp Light
Echo
89 Trooper wiring question
by Resman7. 09/05/18 11:48 AM
Gen 1 & 2 Monteros for sale
by . 08/25/18 02:30 PM
0 registered members (), 101 guests, and 6 spiders.
Topics137,912
Posts1,079,635
Members14,783
6 lug GMC wheels fit Toyota? #512466
10/12/04 03:05 PM
10/12/04 03:05 PM
A
Anonymous OP
I'm trashing my old GMC's steel wagon wheel style wheels. They are 6 lug with large center hole.
Not counting off set, will these things fit my Toy?
I guess I could go jack it up and test fit, but why bother if you guys know the answer.
Re: 6 lug GMC wheels fit Toyota? #512467
10/12/04 03:36 PM
10/12/04 03:36 PM
Elbow_Greese  Offline
Three Oaks, MI
They should be the same bolt pattern, just have to check out the center hole and make sure it's big enough.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: 6 lug GMC wheels fit Toyota? #512468
10/12/04 04:25 PM
10/12/04 04:25 PM
abnormaltoy  Offline
Tucson,Az.
They're the same bolt pattern, however, Toyota uses a hub-centric design. The center of a Toyota wheel carries some of the weight by being almost a press fit on the hub. Using a lug-centric wheel puts all the weight on the...lugs. I've read where some guys will machine a sleeve to go on the hub to make up the difference in size. I've never had a problem with lugs snapping off, so I just let it ride.
Mark
I would rather suffer the consequences of a Conservative’s error, than suffer the consequences of a Socialist's intent.
Re: 6 lug GMC wheels fit Toyota? [Re: abnormaltoy] #512469
10/12/04 05:02 PM
10/12/04 05:02 PM
A
Anonymous OP
Thanks!
Looks like I finally have a spare set of wheels for those really big tires I want for xmass. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 6 lug GMC wheels fit Toyota? [Re: abnormaltoy] #512470
10/12/04 05:31 PM
10/12/04 05:31 PM
4Crawler  Offline
N. California. USA *****
Actually, Toyota wheels are lug-centric. That's why you often have trouble with wheel balance if the shop uses the more common hub-centric baancer.
Re: 6 lug GMC wheels fit Toyota? [Re: 4Crawler] #512471
10/12/04 05:43 PM
10/12/04 05:43 PM
A
Anonymous OP
Yep, we covered that several months ago...I think it was me that explained it then and posted a linky about it.
But I've slept since then, so I can't be sure. <img src="/forums/images/graemlins/smile.gif" alt="" />
Basically, if your wheel has lug stud holes that have a flared crosss section and need flared lug nuts, then they are lug-centric and center properly when the lugs are tightened. Those type wheels should not fit tight over the hub.
If the stud holes aren't flared, then they should fit real tight on the hubs and use a different kinda lug nut.
Lug-centric wheels need to be balanced by a shop that has the proper adapters or they will bounce and wobble.
Re: 6 lug GMC wheels fit Toyota? #512472
10/12/04 06:31 PM
10/12/04 06:31 PM
abnormaltoy  Offline
Tucson,Az.
Centric means "at the center" ,the hub is used to center the wheel. This makes for a truer balance.
http://autorepair.about.com/library/glossary/bldef-308.htm
http://www.miata.net/garage/hubcentric.html
My Toyotas came with factory alloy wheels, all of them where almost a press fit on the hub. I've bought aftermarket wheels that are much looser around the hub.
Re: 6 lug GMC wheels fit Toyota? [Re: abnormaltoy] #512473
10/12/04 06:57 PM
10/12/04 06:57 PM
4Crawler  Offline
I am aware of the meaning of lug- vs. hub-centric. My stock steel wheels (1st gen, solid axle) are a loose fit on the hubs, front and rear. This page confirms the lug-centric wheels ont he 3rd gens. I've never used any 2nd gen alloy wheels, so perhaps they are hub-centric on the 2nd gens.
Re: 6 lug GMC wheels fit Toyota? #512474
10/12/04 10:54 PM
10/12/04 10:54 PM
A
Anonymous OP
I purchased some GM rally rims w/ beauty rings / center caps and tires for $40, and they won't fit my truck because the Toyota hub is larger than the GM hub. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: 6 lug GMC wheels fit Toyota? #512475
10/13/04 12:12 AM
10/13/04 12:12 AM
4Crawler  Offline
Its usually the factory wheels (GM, Chevy, etc.) that have problems fitting because of the too-small ID on the center hole. Most of the aftermarket rims have larger ID holes so fit fine. You could have a machine shop turn the center holes larger if needed.
Page Time: 0.011s Queries: 16 (0.004s) Memory: 1.0576 MB (Peak: 1.1915 MB) Zlib disabled. Server Time: 2018-09-24 19:12:13 UTC
