Gen1 2.6L alternator upgrade
by rascott. 09/19/18 05:27 AM
WTB: Mitsubishi Gen1 seatbelt
fuel tank/ separator tanks
by rxinhed. 09/06/18 04:00 AM
1989 LWB A/T Temp Light
Echo
89 Trooper wiring question
by Resman7. 09/05/18 11:48 AM
Gen 1 & 2 Monteros for sale
by . 08/25/18 02:30 PM
0 registered members (), 122 guests, and 6 spiders.
Topics137,912
Posts1,079,635
Members14,783
Page 3 of 4 1 2 3 4
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515113
10/31/04 07:16 AM
10/31/04 07:16 AM
kewlynx  Offline
Fairbanks, Alaska *****
Check out the rest of this website <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
http://www.4x4wire.com/toyota/faq/parts/
**ubi apis- ibi salus**
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515114
10/31/04 07:51 AM
10/31/04 07:51 AM
kyle-22r  Offline
Lacey, WA
If you're gonna swap axles, go with an IFS 86-95 rear axle. It is 3" wider, and has larger brake drums.
That's cool, like the 3" wider and bigger brakes.
<img src="/forums/images/graemlins/confused.gif" alt="" /> Factory axle Gear ratios. <img src="/forums/images/graemlins/confused.gif" alt="" />
What years, what ratios, manual vs auto?
What years will work together, front and rear?
factory ratios are as follows:
'79-80 - 4.375
'81 - 3.90
'82-up base model with 5 speed - 4.10
base model auto - 4.30
5 speed with 31" tire package - 4.56
auto with v6 and 31" tire package - 4.88
just make sure you get both ratios the same in the front and rear and you'll be fine. if you're pulling gears from an '86-up(IFS) remember that you'll only be able to use the rear third members since the IFS trucks have a 7.5" front diff. however you can still use the rear thirds in the front or rear of your truck as they're the same 8" diff
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" />
20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed
22R-E, W56, the dd!
Re: What Engine will Fit My '81 4X4? [Re: kyle-22r] #515115
10/31/04 04:39 PM
10/31/04 04:39 PM
P
Packrat  Offline OP
Fresno Calif.
You guys have been more help than I could ever have dreamed.
THANKS.
Now that I have the intel <img src="/forums/images/graemlins/kewl.gif" alt="" /> I just need to find the parts.
Wish me luck in finding them soon <img src="/forums/images/graemlins/smile.gif" alt="" />
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Building 88 Toyota 4X4 (7S Desert race truck)
Next 81 Toyota 4x4 (drive train conversion)
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515116
11/06/04 03:35 PM
11/06/04 03:35 PM
P
Packrat  Offline OP
Fresno Calif.
Saw an article in a copy of September Four Wheeler. A replacement kit to replace the Birfield joints in the front axle. Made by Yukon Gear & Axle, called the "Birfield Eliminator Kit". Anyone tried this kit yet? Heard any of the Good, Bad, or Ugly about it?
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515117
11/07/04 03:36 AM
11/07/04 03:36 AM
kyle-22r  Offline
Lacey, WA
i think they've just become obsolete. bobby long(the guy who makes longfield joints) recently came out with a chromoly/300m birfield and 30 spline inner shafts(stock is 30 spline at the diff, but 27 at the birfield). stress testing showed that they were nearly on par with 35 spline dana 60 shafts in strength.
a set of these(2 shafts and 2 birfields) is about $650-ish, about the same price as a birf eliminator kit, and it's a drop-in improvement
'91 4x4 shortbed
22R-E, W56, the dd!
Re: What Engine will Fit My '81 4X4? [Re: kyle-22r] #515118
11/07/04 02:58 PM
11/07/04 02:58 PM
P
Packrat  Offline OP
Fresno Calif.
I don't know <img src="/forums/images/graemlins/confused.gif" alt="" /> about that.
My philosophy about vehicles is: the more automated, complex or the more moving parts the more likely it will break at the most inopportune time.
<img src="/forums/images/graemlins/rodent.gif" alt="" /> Ever met Murphy and his laws? <img src="/forums/images/graemlins/rodent.gif" alt="" />
I think the Birfield fits 2 out of 3 of these. Where as the Spicer is a pretty simple design and has been around for a long time.
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515119
11/07/04 04:07 PM
11/07/04 04:07 PM
P
Packrat  Offline OP
Fresno Calif.
Found a good buy on a 1989 Toyota 4Runner V6, 4X4.
Is the V6 and trany a doable swap?
How about the electronics? Too new a vehicle?
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515120
11/08/04 01:45 AM
11/08/04 01:45 AM
kyle-22r  Offline
Lacey, WA
the V6 in there wouldn't be worth your time to swap in. doesn't make all that much more power than the 22R, gets far worse mileage and it's hard to work on. the 3.4 used in '96 and later trucks is a much, much better engine
as for the birfield vs spicer deal, a birfield joint transfers power much more smoothly than a u-joint, especially at full lock. that, and if you break a birfield it usually doesn't take out the axle shaft like a u-joint will(or vice versa) <img src="/forums/images/graemlins/kewl.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: What Engine will Fit My '81 4X4? [Re: Packrat] #515121
11/13/04 08:39 PM
11/13/04 08:39 PM
A
have 7mge supra (inline six) in my 85. bolts in. see supracharged.com for wealth of info for this swap. 200hp realy wakes the truck up.
Re: What Engine will Fit My '81 4X4? [Re: kyle-22r] #515122
11/14/04 02:20 PM
11/14/04 02:20 PM
A
Thanx for the info Kyle....
I knew it was something odd like that....
I have an 80, but someone put in a 20R/22R Hybbie, and it has a mech pump on the head....I dont know if there is still a pump in the tank, or if its even still hooked up... <img src="/forums/images/graemlins/frown.gif" alt="" />
Page 3 of 4 1 2 3 4
Page Time: 0.011s Queries: 16 (0.004s) Memory: 1.0641 MB (Peak: 1.2079 MB) Zlib disabled. Server Time: 2018-09-24 13:00:20 UTC
