64
guests, and 2
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS
[Re: osirus]
#547249
11/01/07 04:09 AM
If your talking about the intake gasket just get some gasket material and make a new one, other than that you will need to go to the dealer, no one wants to do that. Dennis
[Re: DennisThompson]
#547250
02/25/08 02:14 PM
Are NGK plugs ok to use, or is there a preferred brand I should be installing?
[Re: homerdog]
#547251
02/25/08 03:06 PM
Kia Moderator Emeritus
Are NGK plugs ok to use, or is there a preferred brand I should be installing? NGK's are the OEM plug so yes, they are OK to use.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Hal2000]
#547252
03/05/08 12:27 AM
I can't get the part numbers to bring up anything on the kia parts site. Is there a space somewhere that is missing? I think I recall having troubles getting anything to display when I failed to fill in all of the input fields (# of doors, EX? etc.) If you still have trouble make sure you filled everything in... leadbelly
'99 Sportage 4dr EX 5-speed, unmolested '98 Sportage 4dr Auto 2wd '96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
#547253
04/29/08 05:57 PM
Did you find a blown spark plug? Cause mine is doing this and I think that is what we found.
[Re: Enlew]
#547254
12/20/09 03:12 AM
Just changed the plugs today (and V-cover gasket)....used 4 spark Bosch.....They now sell them all covered with paper, and gap set was always supposedley pre-set! <img src="/forums/images/graemlins/kewl.gif" alt="" />
*dot not touch this pre-set gap*
....like I had done before <img src="/forums/images/graemlins/scared.gif" alt="" />
Engine idles perfect and I would not change a thing.
The reason that these plugs did not work for me before is prolly cause I tried to put the gap back to what we all are supposed to have.
Just don't touch them (except to put anti-sieze) on them!
Good luck... <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Hydra747]
#547255
05/05/10 07:41 AM
Any recommendation on a specific brand? (I saw Denso for $24 and Karlyn for $51 or any other...) Thanks, Lior
[Re: LiorB]
#547256
05/05/10 07:44 AM
Sorry, I forgot to mention I meant the plug wires... <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: LiorB]
#547257
05/08/10 05:27 PM
If yours is a DOHC all you need is 2 wires, The factory Kia wires are about all I've found. You didn't say what year Sportage you had.
#547258
05/09/10 03:34 PM
It's the DOHC (2001) Thanks, Lior
