by rascott. 02/21/19 02:19 AM
by Casey. 02/20/19 12:49 AM
1989 4Dr - LS V6 - For Sale
by tdf46. 02/19/19 07:49 PM
Rebuild a Power Steering Pump
by Bigshankhank. 02/19/19 01:44 PM
Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
Upgrade City
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
by Crops. 01/30/19 08:17 PM
0 registered members (), 122 guests, and 5 spiders.
Topics137,972
Posts1,079,928
Members14,882
Page 3 of 7 1 2 3 4 5 6 7
Re: StinkyFab Heavy Duty TieRods. [Re: StinkBug] #550488
01/21/05 03:35 PM
01/21/05 03:35 PM
matthew  Offline
Richmond, VA
Thanks for the Sticky Randii, and the tally thread. In order to get things going I'd like to try to get at least 10 people willing to put down a deposit. The deposit amount would be $75 per set, or a little under 30%. If we can get these kind of numbers together it should allow me to do a production run, including all of the preordered TieRods and a few extra sets as well.
Thanks Everyone
Dallas
fwiw...............i 100% agree with this. the TRE's are the right solution.
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: StinkyFab Heavy Duty TieRods. [Re: StinkBug] #550489
01/24/05 07:23 AM
01/24/05 07:23 AM
houlster  Offline
Isuzu Moderator
Mesa, AZ
These are really nice and a serious improvement over stock. If I still had the need, I'd be signed up for a set. I swapped way too many broken ones on the trail.
--Dan
Re: StinkyFab Heavy Duty TieRods. [Re: houlster] #550490
01/24/05 10:04 PM
01/24/05 10:04 PM
A
Just leetting you know I will pick up a set later, found a deal on a winch I can't pass up, so no funds at the moment, maybe a month I will pick up a set.
Re: StinkyFab Heavy Duty TieRods. #550491
01/27/05 02:12 AM
01/27/05 02:12 AM
S
Sammy  Offline
SoCal
Hey Dallas,
Will these allow more down travel than stock? As I'm sure you know, our rigs are limited by how much down travel we allow in the IFS due to the tie rods boots getting pinched.
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: StinkyFab Heavy Duty TieRods. [Re: Sammy] #550492
02/04/05 01:54 AM
02/04/05 01:54 AM
matthew  Offline
Richmond, VA
Hey Dallas,
what? care to elaborate on this theory <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: StinkyFab Heavy Duty TieRods. [Re: Sammy] #550493
02/04/05 05:05 AM
02/04/05 05:05 AM
mlclark  Offline
Isuzu Moderator
Ventura County *****
Actually, minus shocks, travel is first limited by the upper ball joint, followed by the outer CV joint. Tie-rods are not an issue.
Michael
Re: StinkyFab Heavy Duty TieRods. [Re: mlclark] #550494
02/04/05 05:14 AM
02/04/05 05:14 AM
matthew  Offline
Richmond, VA
michael...i just wanted someone else to realize this...i know you know it <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: StinkyFab Heavy Duty TieRods. [Re: matthew] #550495
02/04/05 08:18 AM
02/04/05 08:18 AM
S
Sammy  Offline
SoCal
What's up Matt, long time no talk.
Per this post:
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
Sorry, I don't know how to how to turn the above into a nice neat link. Anyway, I've got one of Joe's diff drops sitting in my garage waiting for the weather to heat up, so the cv's are not an issue. Looking at my rig as it stands right now (Calmini control arms with 3" torsion bar lift, no ball joint flip), when it's reached it's current max amount of down travel, the tierods boots are very close to being crushed. My plan was to flip the ball joints and, if that works out ok, maybe add spacers to increase my down travel a bit more. Per the above link, if Dallas' "Stinky Rods" allowed more down travel without me needing to change the boots all the time, I would be that much more justified in spending the $$$ (an added benefit in addition the the increased strength). As also mentioned in the other thread, the ball joints would the other obvious issue. I would still like to see someone come up with a wedge shaped ball joint spacer to decrease that sharp angle.
Sorry mods, don't mean to hijack this thread into something that has already been gone over in a past thread.
Sammy
Re: StinkyFab Heavy Duty TieRods. [Re: Sammy] #550496
02/04/05 03:23 PM
02/04/05 03:23 PM
matthew  Offline
Richmond, VA
what you are asking for is a TRE that has a higher angle of Mis-alignment than the stock isuzu TRE. i am sure that a comparative between the max angles achived on the Spicer rod end Dallas is using and the OEM isuzu TRE could be done, but............
this is a moot point i think. Tie Rods set the toe in and are therefore a fixed length. what you are suggesting is that with your modifications you are getting to the max working limit of the TRE which is inturn as you are calling it "limiting" something.
if the boots are ripping, just swap to a shell type Poly boot instead of the stock rubber boot.
my point is that you are asking this product to do something that is beside the point. This is all about eliminating a weak spot that is a very common break on the IFS.
honestly this is a very good solution.
Re: StinkyFab Heavy Duty TieRods. [Re: houlster] #550497
02/08/05 05:09 AM
02/08/05 05:09 AM
Chris Perosi  Offline
Isuzu Staffer Emeritus
Little Falls, NJ
--Dan
Haha! I have proof!
Houlster pulling recently ruptured tie-rod off of truck.
Dan welding said tie rod back together thanks to an extra battery (sorry about melting that post on ya buddy...)
Gee, I wonder why Dan broke so many tie-rods... Let's see... This is what Dan did just a short while before lunch (which was when he welded it back together):
Need a ballast or five, Dan? <img src="/forums/images/graemlins/wink.gif" alt="" />
Can't ya keep those damn tires on the ground man? Well, I guess that's why you went to the solid axle, huh? <img src="/forums/images/graemlins/wink.gif" alt="" />
This photographic flashback brought to you by Moab 'Zu Zoo. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Anyway, back on topic... Since I now actually have a vehicle to use these on, I will weasel the money out of the checking account and send you a deposit Dallas. Need to give it a few weeks tho, so don't put me on the list just yet...
-Chris
P.S. Dallas, you should get someone who's quick with flash to program the above pictures into an ad you can run on your site, if Dan would allow it.... JasonB comes to mind but I haven't seen him on here in awhile -- next one to jump to my mind is Smiley cause he sent me a flash he did, quite nice -- and you know Smiley has a way with words... <img src="/forums/images/graemlins/wink.gif" alt="" />
Chris Perosi
Isuzu Editor Emeritus
OutdoorWire, Inc.
Page Time: 0.014s Queries: 16 (0.006s) Memory: 1.0767 MB (Peak: 1.2160 MB) Zlib disabled. Server Time: 2019-02-21 18:58:50 UTC
