89 GEN1 LWB Headlight Washer Pump Rebuild
by chadzeilenga. 06/24/18 06:13 AM
1989 LWB A/T Temp Light
by chadzeilenga. 06/24/18 05:36 AM
GEN1 LWB Radio reception
by chadzeilenga. 06/24/18 05:34 AM
by rascott. 06/20/18 12:47 PM
Bumper?
by TOASTY. 06/20/18 02:59 AM
Instrument Cluster Fuse
by rxinhed. 06/17/18 04:50 PM
Winch bumper
Gen 2 seat options
My '88
4x4Wire YJ
0 registered members (), 92 guests, and 3 spiders.
Topics137,876
Posts1,079,486
Members14,783
Clutch Questions #57285
06/28/03 05:30 AM
06/28/03 05:30 AM
A
Anonymous OP
Got a few questions regarding my clutch.
I have an 82 4x4 with 5-speed. I was driving home and the clutch pedal got softer than normal and the clutch would not release. I had to rev match to shift all the way home. I removed the clutch master cylinder and pulled it apart and cleaned it I also did the same to the Slave. I bled the system and it appears to be working correctly.
First question is how far out does the slave push the rod? I am not sure if it is pushing the lever to the throwout bearing enough.
I have the Transmission ready to be removed but I hate to take it out if there is some easy thing that could be wrong.
The Clutch only has maybe 20,000 mile on it so I don't think that is would have failed yet.
Thanks,
Troy
Re: Clutch Questions #57286
06/27/03 06:12 PM
06/27/03 06:12 PM
Bonzai  Offline
Memphis, TN
Sounds like your problem is in the hydraulics. Have you noticed any fluid leaks?
Have you noticed the fluid level dropping?
If you got it bled properly, and it continues to give you problems, I would suspect the clutch master or the slave is going out on you.
Taylor...
89 Toyota P/U, 22re, SAS, 4" All-Pro Fronts, Chevy rears, 33x12.50's...
Re: Clutch Questions #57287
06/27/03 06:38 PM
06/27/03 06:38 PM
A
Anonymous OP
Bonzai,
It does not appear to be leaking at all. when it stopped working the clutch pedal got a lot easier to press in. But I have watched the movement of the slave rod when the clutch is pressed and it appears to be working correcty. I think that I will replace the Master Cylinder first and see if that fixes it. thanks for the reply
Troy
Re: Clutch Questions #57288
06/27/03 06:40 PM
06/27/03 06:40 PM
Red_Chili  Offline
Toyota Section Staffer
Littleton, CO
Do 'em both, they are not expensive from NAPA and carry a lifetime warranty. If one is gone, the other is close on its heels. Same fluid, after all...
Avoid AutoZone, et. al.
-Bill
'87 4Runner w/ '96 5VZ-FE, 'Red Chili II'
'97 Taco XtraCab 3RZ-FE, 'BlackBean'
TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator
"He who stops being better stops being good." -Oliver Cromwell
Re: Clutch Questions #57289
06/27/03 06:47 PM
06/27/03 06:47 PM
Bonzai  Offline
Memphis, TN
Hope you get it fixed!
Ditto on what Bill said. Do them both and you should have everything corrected.
Taylor...
Re: Clutch Questions #57290
06/27/03 07:01 PM
06/27/03 07:01 PM
gota87toy  Offline
Prescott, Az
Both the clutch slave and master cylinder are rebuildable at about 25 bones for both kits. If the bores are good, it's a he!! of a lot cheaper than buying aftermarket junk.
"Nine-11 changed me," he said. "I'm shocked that it didn't change the whole country, frankly."
Dennis Miller
Re: Clutch Questions #57291
06/27/03 07:02 PM
06/27/03 07:02 PM
A
Anonymous OP
One more quick question. I know that there is a soft line that runs from the frame to the hard line that goes to the Slave. Are these prone to going bad as well. I am going to replace it since I have everything disconnected but I though that I would ask.
--Thanks,
Troy
Re: Clutch Questions #57292
06/28/03 02:09 AM
06/28/03 02:09 AM
A
Anonymous OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by tbradshaw:
<strong>One more quick question. I know that there is a soft line that runs from the frame to the hard line that goes to the Slave. Are these prone to going bad as well. I am going to replace it since I have everything disconnected but I though that I would ask.
--Thanks,
Troy</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">YES. A telltale sign of a bad clutch hose will be dark, gooey, yucky, icky and nastificated
hydraulic fluid in the master cylinder reservior.
This simple hose has been the cause of many, many mis-diagnosed clutch jobs since, well, since there has been clutches <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" />
Re: Clutch Questions #57293
06/28/03 05:29 AM
06/28/03 05:29 AM
OOP'S  Offline
Roseville, CA, Gateway to the ...
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans"> This simple hose has been the cause of many, many mis-diagnosed clutch jobs since, well, since there has been clutches </font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">
This should read Juice (hydraulic) clutches. Most all clutches were mechanical in the old days, pre-60ís!!!!!! <img border="0" title="" alt="[Razz]" src="images/icons/tongue.gif" />
<small>[ June 28, 2003, 12:30 AM: Message edited by: OOP'S ]</small>
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Page Time: 0.008s Queries: 14 (0.003s) Memory: 1.0280 MB (Peak: 1.1416 MB) Zlib disabled. Server Time: 2018-06-24 12:34:20 UTC
