1999 Montero Sport Limited 3.5L crawler build
by ES_97Sport. 03/15/18 10:43 PM
R&P Contact Pattern
by 4x4Wire. 03/15/18 07:50 PM
March recipe from CanCooker - It's yummy!
by 4x4Wire. 03/14/18 07:07 PM
Raider: cracked upper control arm. Alternates?
by rxinhed. 03/06/18 02:08 AM
Carb Question
by rxinhed. 03/02/18 03:44 AM
O2 Sensor 1989 Raider V6
by rxinhed. 03/02/18 03:41 AM
R&P Contact Pattern
by JeeperDan. 03/15/18 01:14 PM
by TresMon. 03/05/18 04:27 PM
by losduarte. 03/01/18 07:45 AM
I have broken the door handle of my 1989.
by bblauve. 02/27/18 11:56 PM
Front end help desperately needed.
by SuprXr. 02/26/18 01:24 AM
My '88
4x4Wire YJ
0 registered members (), 160 guests, and 5 spiders.
high swr #60836
04/22/03 01:39 AM
04/22/03 01:39 AM
Anonymous OP
hey guys
i got my rear bumper two days ago with my cb antenna mount on it. for some reason, when i put my cb antenna on the mount, the swr reading is unbelievably high. i tried to tune it, but nothing works..any suggestions?
Re: high swr #60837
04/22/03 02:45 AM
04/22/03 02:45 AM
Randy Braley  Offline
Kansas City
A friend of mine with a J#@p had the same problem and fixed it by running a special ground wire from the mounting point to a good ground.
Randy Braley, Shawnee, Kansas
2000 4Runner: TJM T-15, Warn M8000, Elec Rear Locker, Sonoran Steel Shackle Hangers, OME, Maniac Sliders, Cobra 75 WX ST w/ FireStik II, BFG AT KO's 265/75 R16
TLCA #12443
Re: high swr #60838
04/22/03 02:47 AM
04/22/03 02:47 AM
aowRS  Offline
Ellicott City, MD
Is the antenna mounting position low on the bumper, or mounted atop a spare tire carrier? I've read that while a low mount is good for keeping your antenna out of the branches, it'll wreak havoc with the signal, as the antenna sits adjacent to the steel structure of the truck - not above it.
2001 4Runner SR5 4WD, Dorado Gold, 303,000+ miles
2014 Audi A4, Monsoon Gray
1995 Porsche 993, Polar Silver
Re: high swr #60839
04/22/03 02:46 PM
04/22/03 02:46 PM
fourwd1  Offline
Baltimore, MD USA
Andreas is correct, a bumper mount and a shortened antenna is not a good combination. You didn't say what vehicle or type of antenna your using, so it's hard to give specific help for your problem. But any antenna needs to be mounted on a surface area of sheetmetal to work properly (refered to as a groundplane, not to be confused with an electrical ground). Bumpers, brushguards, spare tire mounts, etc are not good mounting points if maximum range is desired.
Typically, if your VSWR is high (> 3:1) and adjusting the antena has no effect, a wiring or mounting problem is indicated. The coaxial cable could have an open or a short at the connector end or the antenna end, or the antenna mount could be installed incorrectly with the same result.
Try the SEARCH function for more info, this subject has been discussed to death, and much info is available in the archives.
Re: high swr #60840
04/22/03 03:14 PM
04/22/03 03:14 PM
Dandeman  Offline
Toyota Moderator
Chapel Hill, NC
Here's the link to more detailed discussion about acheiving a good RF ground http://www.4x4wire.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=13;t=010309#000021
Understanding what it takes to achieve a good RF ground for the antenna is key...
As discussed, the "counterpoise" or ground plane provided by proper grounding to the rest of your vehicle must be effective to get the SWR down..
What works for DC grounds will not always work as an RF ground. The above link explains...
Re: high swr #60841
04/22/03 04:16 PM
04/22/03 04:16 PM
jataga  Offline
Atlanta, GA
You have a short.
Make sure you follow the directions to install the antenna to the T. It is probably not your cable that is shorted but the mount that is not secured properly or you might not have the correct washer in there. Same thing happened to me. After checking it all out, it was the mount.
99 Limited 4Runner 4WD
ARB front Bumper Kennesaw rear bumper
WARN 9500 Winch
Hella 4000s
Re: high swr #60842
04/23/03 05:15 AM
04/23/03 05:15 AM
Anonymous OP
I hope this can explain it.
Just made this page.
This is how mine is done, and shows you what must be isolated as to not get a ground to short condition.
Moderated by  Adam F, Dandeman, kewlynx
Page Time: 0.009s Queries: 14 (0.004s) Memory: 1.0148 MB (Peak: 1.1172 MB) Zlib disabled. Server Time: 2018-03-21 12:53:47 UTC
