by TresMon - 07/12/20 06:52 PM
Hankook or Nitto?
by 4x4Wire - 07/12/20 02:16 AM
87 Gen1 Rebuild in Kansas
by polar - 06/27/20 11:11 PM
by polar - 06/17/20 09:19 PM
by - 06/14/20 05:54 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
0 registered members (), 89 guests, and 6 spiders.
Topics138,123
Posts1,080,667
Members15,072
Page 4 of 14 1 2 3 4 5 6 13 14
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: DamKia] #615805 12/27/07 12:07 AM
logansportage Offline
Put a small bead of RTV around the edge of the hub just before the O ring to seal it against the hub mounting flange. This will help seal out water and dirt. This helps a lot!
Also you will want to pull them off at least once a year to grease them.
You should also do this after any deep water crossing.
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: DamKia] #615806 12/27/07 01:50 AM
S
snowboardvdr Offline
thanks <img src="/forums/images/graemlins/cheers.gif" alt="" /> i should get them tomorrow. cant wait to get my 4wd back. id like to lift it but maine laws r so strict. ill buy the next round <img src="/forums/images/graemlins/cheers.gif" alt="" /> thanks
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: snowboardvdr] #615807 12/28/07 12:33 AM
S
just put them on today. took 30min, the pic on the instructions was small and couldnt tell witch connector to unplug, is it the one on the airbox or somewhare else? is there a prob if i dont disconnect it? works awsome still, good test day we got about 6 more inches of snow. i forgot how it feels to drive with 4wd.. its awsome.. thanks for the input.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: snowboardvdr] #615808 12/28/07 10:00 PM
Axe Man Offline OP
Kia Moderator Emeritus
It is important that you disconnect the vacuum solenoid once the manual hubs are installed. This will prevent dirt and water from entering the hub area when in 4H and 4L.
It's a simple operation. Follow the vacuum line from the driver's side fender. It should go up behind the air filter and meet with the vacuum line from the passenger side. At that point you should see the vacuum solenoid with the electrical connector coming up from the bottom. Pull off the connector and tape it back. That's all that's needed.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: Axe Man] #615809 12/29/07 06:03 AM
S
yea i found it, i just followed the line till i found it. i cut the lines to the hubs and pluged the inlet tube also. im gonna do a wheel bearings this spring. mayb a body lift if i can, gotta check the laws first. thanks man <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: Axe Man] #615810 12/29/07 04:56 PM
S
shellymac Offline
Will the manual 4x4 system work on a 2002 2dr, 5sp sportage? I just bought this Kia in June and found out my 4 wheel drive doesn't work. I want to know I have 4 wheeel drive when I lock it in. I'm sick of not knowing if it locked in or not!!!
Shelly
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: shellymac] #615811 12/30/07 03:45 PM
Axe Man Offline OP
Shelly
Yes. Was discussed earlier in this thread.
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: Axe Man] #615812 01/19/08 05:38 AM
S
SandraK Offline
Axw Man, Thanks for all your very good information, but my problem is the opposite to all above. I do not need the 4WD more than a couple of times a year, so have not missed it until recently noticing a broken vacume line above RH wheel. Traced it and figured it was for 4WD. Got some new hose and replaced it. Now the thing wants to lock in front wheels when in 2H, with some crunching type noise. Stopped that and experimented with it by rocking car back and forth by hand. With engine off, shafts were stationary. Start motor (gearbox in neutral) and rock, both shafts rotate forward and back as they should in 4WD. Pull new hose off and both shafts stationery. Plug engine end of hose to RH wheel and LH shaft rotates forward and back so LH hub locked in while RH shaft counter rotates so front diff works. With motor running and transfer case in H2, connect hose and can hear hub lock in. I guess the question is - is there a problem with the solenoid, or does the vacume need to be connected in a special way to fix it. Since then, I have been just running RWD with hose off. Any help will be Great. PS, do not really want to change to manual hubs.
Thanks. SandraK
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: Axe Man] #615813 01/27/08 09:40 AM
brian04151980 Offline
are the warn hubs sold in pairs or do i have to erder two
Re: READ FIRST IF YOUR 4WD DOES NOT WORK [Re: brian04151980] #615814 01/27/08 04:34 PM
Axe Man Offline OP
Sold in pairs.
PHP: 7.2.31 Page Time: 0.032s Queries: 16 (0.011s) Memory: 2.9045 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2020-07-15 23:44:08 UTC
