89
Posts1,080,941
Re: hubs
[Re: ChrisB]
#615845
04/05/09 07:00 PM
My warn 60247's should be in tuesday <img src="/forums/images/graemlins/smile.gif" alt="" />.Then its wheeling time. Im so sick of this thing getting stuck because the 4x4 didnt work before.
01 Kia sportage,Removed front bumper,Warn manual hubs,
Make it Break it
Re: hubs
[Re: ChrisB]
#615846
04/08/09 04:14 AM
They just arrived.They are already on the car.4 wheel drive actually works now.Will test them in the wash tomarow.What kind of grease should i put inside them? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Make it Break it
Re: hubs
[Re: ChrisB]
#615847
05/07/09 01:52 AM
Re: hubs
[Re: 2002_Sporty]
#615848
07/01/09 01:42 PM
just wondering if the vacuum lines that go to the hubs is the line that comes out were the brake line comes out at the wheel well.
Re: hubs
[Re: budicexxx]
#615849
07/07/09 10:20 PM
just wondering what might be the problem is when i put my transfer case in 2High that the shaft from transfer case to the front diff. still turns...what might be my problem.
Re: hubs
[Re: budicexxx]
#615850
07/07/09 11:15 PM
also just pulled off one front hub....is it normal to have play when i move the end of the shaft in the front rotor assenbly.
Re: hubs
[Re: budicexxx]
#615851
07/08/09 09:22 PM
Kia Moderator Emeritus
just wondering if the vacuum lines that go to the hubs is the line that comes out were the brake line comes out at the wheel well. Yes, and if you follow the vacuum line it goes to a fitting on the back of the hub.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
Re: hubs
[Re: budicexxx]
#615852
07/08/09 09:27 PM
just wondering what might be the problem is when i put my transfer case in 2High that the shaft from transfer case to the front diff. still turns...what might be my problem. With the transfer case in 2H the front driveshaft should be free and not turn. With the vehicle on the ground crawl underneath and try to turn the shaft. It may be hard to turn but it SHOULD turn. If it doesn't there's a chance that a hub is frozen in the engaged position.
Re: hubs
[Re: budicexxx]
#615853
07/08/09 09:28 PM
also just pulled off one front hub....is it normal to have play when i move the end of the shaft in the front rotor assenbly. There should be some play but I don't recall how much.
Re: hubs
[Re: Axe Man]
#615854
07/09/09 01:23 AM
just wondering what might be the problem is when i put my transfer case in 2High that the shaft from transfer case to the front diff. still turns...what might be my problem. With the transfer case in 2H the front driveshaft should be free and not turn. With the vehicle on the ground crawl underneath and try to turn the shaft. It may be hard to turn but it SHOULD turn. If it doesn't there's a chance that a hub is frozen in the engaged position. K so i just crawled under and the shaft only turns maybe quarter turn and then wants to turn the front diff. So this means that one or both of the hubs are stuck. Hmmmm
