by rascott. 09/16/18 03:23 PM
WTB: Mitsubishi Gen1 seatbelt
fuel tank/ separator tanks
by rxinhed. 09/06/18 04:00 AM
1989 LWB A/T Temp Light
Echo
1990 GEN1 Rear Bumper Removal
by rxinhed. 08/28/18 01:03 AM
89 Trooper wiring question
by Resman7. 09/05/18 11:48 AM
Gen 1 & 2 Monteros for sale
by . 08/25/18 02:30 PM
Topics137,911
Posts1,079,633
Members14,783
Page 1 of 10 1 2 3 9 10
2.6 rebuild Q's(More, and More Updated Pics) #626105
07/13/05 10:18 AM
07/13/05 10:18 AM
bob large  Offline OP
Coeurdalene ID
[color:"red"] Updated pics [/color]
So I decided to rebuild the 2.6 I pulled out of my junk trooper instead of just stuffing it in the amigo. <img src="/forums/images/graemlins/drunk.gif" alt="" /> I havenít gotten the rebuild kit yet. And Iíve never done an engine rebuild before this. Iím just now stripping the engine down. And Iím going to have to get the block cleaned up, bored out, and all that jazz.
So what exactly should I have done?
And what kind of prices should I be looking at from a machine shop?
What engine kit should I get?
With what parts included?
And any other info I should be aware of?
My current links for rebuild kits.
http://www.allstateengine.com/
http://www.rpmmachine.com/enginerebuildkitsisuzutop.html
http://www.greenbaypartsworld.com/cgi-bin/webstore.cgi?page=4ze1a
Engine pics, as it sits right now. <img src="/forums/images/graemlins/patriot.gif" alt="" />
http://community.webshots.com/album/395413791AOUBTq
http://community.webshots.com/user/boblarge34
Re: 2.6 rebuild Q's [Re: bob large] #626106
07/13/05 11:08 AM
07/13/05 11:08 AM
Madcat  Offline
Denham Springs, La.
You already mentioned the major ones, also don't forget to have the crank turned and the proper main and con rod bearings. Depending on the overbore you go with your going to need to get the new pistons before the bore job so the shop gets in spec, of coure the actual cylinder condition will control the amount you need to bore over.
I had my local shop bore the cyliders .030 over and press on the new pistons to the con rods for $80, and turn the crank for $80 but I had to pay for a set of bearings from somewhere else.
I didn't see a price on allstates site nor a list of parts included.
GreenBay is a little over priced especially seeing as you have to pay even more to get a NEW oil pump.
RPM machine seems more cost freindly and the price of the Gold kit includes a NEW oil pump.
As for the pics of your engine ...kinda reminds me of mine a few months ago <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: 2.6 rebuild Q's [Re: bob large] #626107
07/13/05 02:22 PM
07/13/05 02:22 PM
marcucci  Offline
Dallas/Fort Worth, TX, U.S.A.
I would recommend factory parts, but that's because my 2.6 has 250k miles on it's factory parts. smile
If it's an older 2.6 I would consider upgrading the upper manifold half, throttle body, intake, and MAF to the newer Amigo unit (I think 93 and newer). This alone will increase performance, though I would recommend a Delta or Calmini cam to go along with it.
As for the rebuild, DEFINITELY lighten the crank some and have everything balanced. The cost for this will be relatively minimal and the gains will be worth it.
I can guarantee you that you will need oversized pistons, get them and have the machine shop properly bore and hone to fit the new pistons individually. Usually, for not much more, they will do the bottom end assembly for you. If you have found a shop you can trust, I would just do this.
Re: 2.6 rebuild Q's [Re: marcucci] #626108
07/13/05 11:01 PM
07/13/05 11:01 PM
Coeurdalene ID
Well I just got off the phone with a local machine shop and they gave me some prices.
Bore & hone 40
Grind crank 60
Vat the block 15
Install cam bearings 15
Resize rods 30
Valve job 50
Pressure test 25
Resurface head 25
Paint the block 20 to 40
Press piston 18
250 for engine kit
includes complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs timing kit & oil pump.
Anything else I should be looking at?
Prices look good?
Steve C
Re: 2.6 rebuild Q's [Re: bob large] #626109
07/14/05 12:06 AM
07/14/05 12:06 AM
thepcguy  Offline
Illinois, USA
I personally don't know the going rate of engine rebuilds, but that looks pretty darn nice for the price. Tempted to go pull a junkyard motor and have it rebuilt :), then put that in my trooper and have the one in the trooper rebuilt as a spare smile. ::chuckle:: But alas, it's running too good, and it's not necessary.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: 2.6 rebuild Q's [Re: bob large] #626110
07/14/05 12:43 AM
07/14/05 12:43 AM
tinytrooper  Offline
tn
The 2.6 doesn't have cam bearings. The cam rides in the head on journals and caps...Saving money there...
Re: 2.6 rebuild Q's [Re: bob large] #626111
07/14/05 03:59 AM
07/14/05 03:59 AM
E
EricW  Offline
Arnold,MO (St Louis)
I just recently rebuilt the 2.6l in my '91. The priceing you listed is fair, but do not order the rebuild kit until
you have all your machine work done. This will keep you from having the wrong bearins and rings.
Pay attention to the location and orientation of the thrust washers. One other thing the have checked/done is to have the block decked.
Good luck with the rebuild
1996 Trooper S 3.2 5sp OME919/ProComp ES9000
BFG Dueler A/T REVO 265/75R16 w/Snowflakes
1991 Trooper 2.6 5sp 33x12.5 BFG T/A
Re: 2.6 rebuild Q's [Re: EricW] #626112
07/14/05 04:06 AM
07/14/05 04:06 AM
Sc0rp10n  Offline
Tourist central, Maine
Man this is kind of OT but this will make a great archive thread for future references, and its easy to search for \
+engine +rebuild
+2.6 +rebuild
Sorry just think this is a great resource thread.
I hope to someday rebuild my tired little 2.6....somday when I have money haha.
Nick <img src="/forums/images/graemlins/kewl.gif" alt="" />
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: 2.6 rebuild Q's [Re: Sc0rp10n] #626113
07/14/05 04:57 AM
07/14/05 04:57 AM
Coeurdalene ID
block decked
Steve C
Re: 2.6 rebuild Q's [Re: bob large] #626114
07/14/05 05:03 AM
07/14/05 05:03 AM
onebadtrooper  Offline
Mansfield Texas
I think it is to have the top of the block shaved, to make sure its not warped???? I could be wrong <img src="/forums/images/graemlins/cheers.gif" alt="" />
89 trooper, tera low t-case gears,5.38's, 3" indy4xsus lift3"body lift,safari snorkle,warn winch,custom bull bar,custom rock sliders,warn hubs,35x13.50r15,custom rear bumper trooper pics
Page Time: 0.012s Queries: 16 (0.005s) Memory: 1.0736 MB (Peak: 1.2139 MB) Zlib disabled. Server Time: 2018-09-18 17:19:09 UTC
