93
Posts1,081,774
how big is the rear diff drain plug
#651904
10/02/05 03:13 AM
Just got my new rear 4.88 diff installed and I need to put gear oil in now but I dont have a socket that fits. It seems pretty large maybe 24mm. If anyone knows offhand what size the plug is that would be nice.
Re: how big is the rear diff drain plug
#651905
10/02/05 03:23 AM
24mm, same as the front diff and the tranny and t-case drain plugs. Use only a 6-sided socket.
#651906
10/02/05 03:54 AM
To add, so you're not repeating the other guy's post,
REMOVE YOUR FILL PLUG FIRST or you'll be sayin' bad words! <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />
when you change the oil again after break-in.
[Re: kewlynx]
#651907
10/02/05 04:00 AM
heres an additional question what gear oil is everyone using ? I will be changing mine next week and I was just going to get vavoline. Thanks jed
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
[Re: Hecubus]
#651908
10/02/05 04:07 AM
That's what I use, or Arctic lube. Finally found there's a place in Anchor town that sells Redline.
[Re: kewlynx]
#651909
10/02/05 04:50 AM
I use redline heavy weight shockproof.
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
[Re: CraShYota]
#651910
10/02/05 06:54 AM
You mean i should remove my drain plug before i put the new diff in?is that because its easier or do you have to? if so looks like ill be puling my diff agaian.
#651911
10/02/05 07:02 AM
From your post, it sounds like the diff is installed as well as the drain and fill plugs. If so, then simply remove the fill plug to fill the oil in there and you are set. The comment above was related to a recent thread where someone removed the drain plug in order to change oil. All fine and dandy until they found the fill plug was stuck. So IF you are changing the oil, be sure to remove the FILL plug first then the DRAIN plug last. This way, you'll be able to easily refill the oil you drain out.
[Re: 4Crawler]
#651912
10/02/05 03:13 PM
Replace those plugs with these. After you drag that diff over a few rocks you won't be able to get the socket on the plugs. Part # 90341-18021 in the magnetic flavor, and $3 each with gasket from the dealer. They also work on the tranny and tc. Here is one installed on my FJ40: ![[Linked Image]](http://ratstew.home.comcast.net/fillplug.jpg)
