92
guests, and 4
Posts1,081,774
Re: Need suggestions. 95 SR. Not being very friendly.
[Re: ATCGuy]
#652020
10/04/05 04:03 AM
Just to be sure... was the vehicle out of gear when checking the crankshaft? I've made that mistake when I did mine. Won't turn if in gear.
[Re: off-roader]
#652021
10/04/05 04:34 AM
dude i feel your pain...(rebuild gone terribly wrong). please tell me that this was just a toy and not your only source of travel? sorry man.
bourge
1995 Montero SR 1999 Montero 1974 Ford Bronco
[Re: bOURGE]
#652022
10/04/05 05:03 PM
Can you tell us a few more details? If you say the cams turn but the crank doesn't. Does that mean that you took the timing belt off again? Please fill us in. It moved around like a washing-machine that is out of balance, but did not fire. I just saw that note from your post. That is a really bad sign.
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
[Re: Winston]
#652023
10/04/05 06:26 PM
Yes. We took the timing belt back off. The crankshaft will not budge. I believe my friend even took the intake back off, and the plugs out. Now, I'm in search of an engine I guess. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: ATCGuy]
#652024
10/04/05 06:57 PM
You're supposed to try and rotate the engine over with the belt STILL WRAPPED and installed on the engine. If your rotating the crankshaft only with the Tbelt off, surely your going to run into an open intake/exhaust valve which will stop the rotation. No offense meant but my 1st suggestion is to get another mechanic friend.
Joel, CA
#652025
10/04/05 07:30 PM
I think Joel hit the nail on the head. Fire your friend and tow your car to a real mechanic. Hopefully the dealer. It will be worth an hour of their time to tell you if anything is salvagable.
#652026
10/11/05 04:13 PM
Joel, CA Unfortunately, the FSM has an error in this regard. <img src="/forums/images/graemlins/confused.gif" alt="" /> I dunno if that same error has made it into the 3rd party service manuals.
-Steve -1995 Montero SR 3.5L V6 DOHC
