Introduction & New Raider
by Bigshankhank. 01/21/19 07:04 PM
My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 128 guests, and 1 spider.
Topics137,963
Posts1,079,874
Members14,875
Page 2 of 2 1 2
Re: 22 R engine id #s [Re: kyle-22r] #682014
01/03/06 05:50 PM
01/03/06 05:50 PM
P
pugski1043  Offline
Connecticut
I did the EFI swap using an 85 carbed block from a 2wd and took everything off of my 94 EFI engine. From what I understand post 85 engines are all interchangeable. You can also look for the flying saucer laser block identifier that is on the exhaust manifold side. I was also told to use the oil pan from the 4wd and also used the 4wd dipstick.
1994 Toyota Pickup 22RE, EB 268 cam , 2.25 LCE exhaust.
1988 Toyota 4Runner, mostly stock but hopefully not for long
Re: 22 R engine id #s [Re: 4WD22R] #682015
01/04/06 03:24 AM
01/04/06 03:24 AM
tgzzzz  Offline OP
Outer Banks, NC
Yeah, it's amazing what some people will tell you....even shops that are SUPPOSED to specialize in Toyotas.....idiots
Feedback: I called the d[st]ealer and the PARTS guy told me all those numbers were the same and implied that I had a couple of rod bearings loose for thinking otherwise.
It's a wonder the world keeps turning ...
87 JX Zuke bone stock almost cherry
86 Heavy Chevy 350 one ton 26' RV
There's always time to do it over.
Re: 22 R engine id #s [Re: tgzzzz] #682016
01/04/06 07:02 AM
01/04/06 07:02 AM
4WD22R  Offline
Glendale, Arizona
WHAT? all the numbers on the block are the same? thats a good one.....what's this world coming too......another reason why I work on my truck and a select number of people that I know personally.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: 22 R engine id #s [Re: tgzzzz] #682017
01/04/06 11:03 AM
01/04/06 11:03 AM
kewlynx  Offline
Fairbanks, Alaska *****
And which numbers were those?
I'm gonna tell you something--
Sometimes you need to be standing at the counter to deal with people. If they still give you the same line of BS, go elsewhere.
As a female, a retired GI (they see you coming), and as a Yotahead, sometimes your PRESENCE exceeds the effectivity of a phone call. <img src="/forums/images/graemlins/evil.gif" alt="" />
**ubi apis- ibi salus**
Re: 22 R engine id #s [Re: kewlynx] #682018
01/04/06 03:43 PM
01/04/06 03:43 PM
tgzzzz  Offline OP
Outer Banks, NC
I hear you Margie, but sometimes I'm just too disgusted by ignorance to argue. Besides, that was my close dealer (30 miles away) and I may need him down the line for something.
Anyhow, from all posts I get that if an engine's got a single timing chain it's gonna bolt to my trans and manifolds which is what I'm after. <img src="/forums/images/graemlins/kewl.gif" alt="" />
And I suppose logically if the engine has a higher # than ~196775, it's newer than my 87 although I now realize that there's no reason to think that a newer block has fewer miles on it than the 210K I've got now.
As I've learned more over the past couple of weeks, I find I'm actually looking forward to the overhaul. I will own a STEEL rail TC guide (and new pistons) by next week. My show truck will soon be a go truck again.
Thanks to everyone. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 22 R engine id #s [Re: tgzzzz] #682019
01/04/06 08:40 PM
01/04/06 08:40 PM
kyle-22r  Offline
Lacey, WA
and for purposes of a rebuild, a block that's seen hundreds of thousands of highway miles is a better candidate than something that's been beaten on out in the woods. the cylinder walls won't generally need as much of an overbore <img src="/forums/images/graemlins/cheers.gif" alt="" />
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" />
20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed
22R-E, W56, the dd!
Page 2 of 2 1 2
Page Time: 0.011s Queries: 16 (0.004s) Memory: 1.0687 MB (Peak: 1.1749 MB) Zlib disabled. Server Time: 2019-01-22 01:56:25 UTC
