87 Gen1 Rebuild in Kansas
by JohnnyBfromPeoria - 02/15/20 03:53 PM
Two Free Bouncy Seats Gen 1
by Malykaii - 02/14/20 03:32 PM
What part of the country do you live in?
by Tuxedo_Ranch - 02/14/20 03:24 AM
Jeep Tent
by winchtrail - 02/10/20 04:38 AM
How to Improve MPG
by 4x4Wire - 02/08/20 01:00 PM
89 Dodge Raider for Sale
by Bigshankhank - 01/30/20 02:08 PM
Steering damper Montero Limited 2001
by Stefano - 01/25/20 07:39 PM
Jeep Tent
How to Improve MPG
by Qusto - 02/03/20 06:49 AM
Twin turbo 6g72 swap
0 registered members (), 206 guests, and 3 spiders.
Topics138,090
Posts1,080,528
Members15,010
'87 22R (carb) rough idle #729973 06/09/06 02:20 PM
P
Packrat Offline OP
My wifeís '87 pickup with a 22R Carbed engine started doing this about 6 months ago.
It would start up cold just fine, warm up and kick down off high idle just like it is supposed to most of the time. Every so often the high idle would be a little rough, then when it kicked down it would die.
It has been progressively getting worse to the point now it does this almost every time. If I can keep it running till it warms up it runs fine after that. One other symptom is #3 and 4 cyl not firing right, spark plugs show dry soot build up.
Done so far:
Compression test, 160 lbs. all 4 holes.
New plugs, wires, cap, Rotor.
New Coil, Fuel filter, Air filter.
Checked all vacuum lines.
No apparent manifold leaks.
Checked valve adj. Right on the money from last adjustment.
FSM EGR tests good. Tap test for sticking good also.
Got me stumped so far. HELP
Thinking about replacing carb with an extra one I have but don't know where to compare numbers for compatibility.
Thought it might be the Igniter but that is a $500.00 SWAG.
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Building 88 Toyota 4X4 (7S Desert race truck)
Next 81 Toyota 4x4 (drive train conversion)
Re: '87 22R (carb) rough idle [Re: Packrat] #729974 06/09/06 02:52 PM
Staceman Offline
First thing to do.
Pull the vac line from the AAP on the carb.
(driver's side towards the front)
Plug both ends.
I'll bet your fixed from there. Same thing on my 85 carb'd truck.
If you are in a colder climate, you'll want to replace the AAP before it gets cold again.
The AAP (Auxillary Air Pump) is specifically designed to add more fuel (richen the mixture) to smooth out the high idle when cold. Once warm, it's supposed to close. As it wears out, it continues adding fuel when it's not needed, therefore, making it run too rich, and that's the soot on you plugs.
Mine was intermittant. Ran like crap after warming up. If I shut it down for a few minutes, it would run good after starting after it was already warmed up.
Re: '87 22R (carb) rough idle [Re: Staceman] #729975 06/10/06 03:16 PM
P
Packrat Offline OP
Didn't have enough (insert name) spay to do a good leak test till yesterday. Picked up two cans of (big guns) starting fluid and did the spray around test. Found a vac leak at the #3 intake runner gasket.
Up till 2100 last night taking it all apart. EXCEPT for the one stubborn bolt (everyone knows that one stubborn bolt all too well) had to be the one at the back of the head holding the water tube clamp. You know the one, wants to break off not break loose. Soaking it with PB blast over night. Getting ready for round two after breakfast.
Re: '87 22R (carb) rough idle [Re: Packrat] #729976 06/12/06 06:12 AM
P
Packrat Offline OP
Well the new manifold gasket didnít cure the problem. Replaced the AAP diaphragm while I was in there. Old one looked ok. Iíve about run out of ideas. I think I will go ahead and change the EGR Valve. It was acting a little funny while I was testing it. Donít know where else to look.
Re: '87 22R (carb) rough idle [Re: Packrat] #729977 06/12/06 09:17 AM
D
Davepet Offline
Define "acting a little funny"?
EGR valves pretty much work or don't work. A blown diaphram is the most common failure in my experience & that's easy to diagnose (won't hold vacuum) so I assume you've checked that. Sometimes they get a carbon buildup & sometimes the plumbing to them does, so if it holds vacuum take things apart far enough to rule that out, but replacing the EGR if it hasn't failed is a waste of time & $.
Dave
Re: '87 22R (carb) rough idle [Re: Staceman] #729978 06/15/06 06:03 AM
ArbitraryNotion Offline
he he... AAP means Aux Accel pump... smile The main accell pump is on the other side with the lever on it.
on the rough idle... did you try turning up the idle? 3 and 4 look sooty? is there black buildup or a different color? are you losing any coolant? while its idling spray carb cleaner all over and listen for changes.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
PHP: 7.2.26 Page Time: 0.034s Queries: 15 (0.014s) Memory: 2.8476 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2020-02-20 15:02:11 UTC
