109
Posts1,080,940
Heater/ AC blower motor not working at all
#743631
08/09/06 10:03 PM
Axe,
The heater/AC blower motor in my 1998 Sportage stopped working all together.
I've been working through the repair manual, but I need to get the Electrical Systems Repair manual section on this.
I think it has a short or a blown internal fuse to the motor. I'm hoping it's a blown internal fuse, but at the same time i'm not because you have to completely remove the motor to check the fuse and to do this you have to discharge the AC system and then have it recharged.
Crap either way. Anyway any help on the Electronic Systems Repair Manual would be nice.
Thanks, Logansportage <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Heater/ AC blower motor not working at all
[Re: logansportage]
#743632
08/15/06 07:01 PM
Axe,
Can you send me ths section?
[Re: logansportage]
#743633
08/15/06 09:38 PM
I have a drawing but I would need to email it to you, and its 4 mb. Everet
[Re: logansportage]
#743634
08/16/06 08:45 AM
Kia Moderator Emeritus
Logan, sorry...I haven't been around lately. Send me an e-mail at mjats@juno.com and I'll forward the schematic to you.
1998 Sportage - Gone. 2004 Honda Civic Coupe. 2007 Suzuki Grand Vitara - She got it.
[Re: Axe Man]
#743635
08/17/06 10:01 PM
Everet,
Thanks.
Axe,
Sent you a mail.
[Re: logansportage]
#743636
08/17/06 10:15 PM
[Re: logansportage]
#743637
08/19/06 02:42 AM
I dropped the fan motor with its mount out of the HVAC uit housing without having to recover the A/C charge. Loosen the screws (as I remember - it's been a year or longer) and it drops right out. Did i do it wrong?? <img src="/forums/images/graemlins/drunk.gif" alt="" />
Paw-paw Don, y'all .
[Re: DSHornet]
#743638
08/19/06 05:40 AM
That's correct. I just pulled one out of the Sportage I'm parting out 15 minutes ago. You just remove the screws and disconnect the wiring and it falls out. Took about 2 minutes. If you need the motor, let me know. Everet
[Re: Everet]
#743639
08/21/06 06:57 PM
Everet,
You're talking about the full motor and not just the resister correct?
Just fixed the problem!!! Was just like Everet said. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Pulled the screws and dropped the motor in under 15 minutes.
The blower motor is positioned just under the fan fins which happens to be a cylindrical type fan that creates a bowl and it is positioned directly below the cold air intake at the base of the window. <img src="/forums/images/graemlins/scared.gif" alt="" /> This means it is in direct contact with the outside world. When I pulled it out the fan bowl was chuck full of leaves and small twigs. <img src="/forums/images/graemlins/barf.gif" alt="" /> (I have trees that line my drive so it is no wonder they are there) When I got the motor out of the housing the bottom was rusted and the insides were packed full of leaves. <img src="/forums/images/graemlins/barf.gif" alt="" />
My problem was a seized bearing due to rust and leaves being packed in there. <img src="/forums/images/graemlins/angry.gif" alt="" /> Cleaned it out and added some grease to the bearing.
Now Im good to go!!! Man I love this form!!! I've spent all summer long with no AC because of a seized bearing that took 1 hour start to finish to fix. The bonus is that since I added grease to the bearing it turns much faster and cools everything down better inside.
This is the reason this form is here!!! Keep up the great work guys!!!
Oh, Everett and Axe here are a couple of cold ones for you guys. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
