89 GEN1 LWB Headlight Washer Pump Rebuild
by chadzeilenga. 06/24/18 06:13 AM
1989 LWB A/T Temp Light
by chadzeilenga. 06/24/18 05:36 AM
GEN1 LWB Radio reception
by chadzeilenga. 06/24/18 05:34 AM
by rascott. 06/20/18 12:47 PM
Bumper?
by TOASTY. 06/20/18 02:59 AM
Instrument Cluster Fuse
by rxinhed. 06/17/18 04:50 PM
Winch bumper
Gen 2 seat options
My '88
4x4Wire YJ
1 registered members (Loosecat), 98 guests, and 5 spiders.
Topics137,876
Posts1,079,486
Members14,783
Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: Southeast Crew Board [Re: sparkem] #758324
10/28/06 08:41 AM
10/28/06 08:41 AM
LandRaider  Offline
Ocean Springs, MS *****
You might want to know what your diff temps are on a regular basis.
I know if my diff runs 210 in the interstate @ 70 with no load, and 240 towing a 2000 lb trailer, that if I am crusing down the highway at 60 mph after a trail run, and its running at 300, then something is wrong. Maybe water, maybe the seal blew out, and I dont have any oil in it.
Frame temp sensor.... well thats excessive, but you get the point. If you had a multi posisition switch, and a good guage, then you could wire, and run a sensor anywhere you pleased.
You know what sparky.... You shoudl start cutting the sensor leads off of all the Gen 2 trucks, and placing them all around your truck switched, so you can see what the various temps are. Underhood ambient, coolant temp, oil pan temp, tranny fluid temp. Stuff like that!! how kick ass would that be! <img src="/forums/images/graemlins/smile.gif" alt="" />
87 Raider 4D56td v5MT1
31's..Basically Stock
Re: Southeast Crew Board [Re: LandRaider] #758325
10/28/06 02:52 PM
10/28/06 02:52 PM
Mad_Scientist  Offline
An Englishman in Huntersville ... *****
Have you guys seen the Top Gear show featuring the Koenigsegg pretty funny.
Talking of interesting cars here's a sound bite for you. It's a 1953 BRM 1.5 litre (that's right) V16 (yes 16 cylinders!) supercharged. 500hp out of a 1.5litre engine in 1953 is quite amazing. This sound was recorded quite recently and the car is owned by Nick Mason. The sound is almost mystical <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Southeast Crew Board [Re: Mad_Scientist] #758326
10/28/06 03:09 PM
10/28/06 03:09 PM
sparkem  Offline OP
Ponchatoula, LA ***
I saw the Koenigsegg on top gear. Those doors are awesome.
Re: Southeast Crew Board [Re: sparkem] #758327
10/28/06 06:47 PM
10/28/06 06:47 PM
fasteddy  Offline
Helen , GA *****
A mind fart. The 29 Merc was an sskl..
In 1949 there was a Porsche-Cisitalia 1.5liter v12 NA motor making 400+bhp on exotic fuels, alcohol/nitrometane stuff.
I like the cobras a lot, but there's something to be said for the Sunbeam Tiger/Alpine with the 260/289/302 for a little more stealth. We forgot the Pant-pant-pant-(overheated)-Pantera's....
Re: Southeast Crew Board [Re: fasteddy] #758328
10/28/06 09:59 PM
10/28/06 09:59 PM
sparkem  Offline OP
Ponchatoula, LA ***
A 1.5L 12 cylinder? Id it have pistons the size of siler dollars?
Re: Southeast Crew Board [Re: sparkem] #758329
10/28/06 11:17 PM
10/28/06 11:17 PM
LandRaider  Offline
My room mate JUST got his Honda Oddessy running. 250 2 stroke on a mini dunebuggy with a CVT comet style clutch. Its pretty retarted fast. Piston the size of a Small Block Chevy!! haha almost. <img src="/forums/images/graemlins/smile.gif" alt="" /> That gocart will ALMOST pull the front wheels off the ground.
Re: Southeast Crew Board [Re: LandRaider] #758330
10/28/06 11:42 PM
10/28/06 11:42 PM
DavidG  Offline
Atlanta, Georgia
My son was playing with one of his new matchbox cars and it reminded me of another unattainable car with a tiny motor and lots of power...the wickedly fast Group (Killer) B Ford RS200
After only one full year of...E2 that produced over 650 bhp.
I've read/heard that in rally trim some of these cars have seen over 2 BAR!
More info:
http://www.rs200.org/
http://www.ianhardy.net/ford_rs200.php
The History
0 ~ 60mph 2.1 Seconds
0-100-0mph in 13.6 sec
2.1 litre 16 valve DOHC turbo engine
Four wheel drive and 650bhp
Body designed by Ghia
200 Built
Double wishbone, twin damper suspension
Front remote mounted gearbox
Not too bad for the 1980's <img src="/forums/images/graemlins/smile.gif" alt="" />
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: Southeast Crew Board [Re: DavidG] #758331
10/28/06 11:51 PM
10/28/06 11:51 PM
sparkem  Offline OP
Ponchatoula, LA ***
Another bad arse 80s car was the Porsche 959
Re: Southeast Crew Board [Re: sparkem] #758332
10/29/06 02:18 AM
10/29/06 02:18 AM
Did you check out the BRM? That's a 1.5L with 16 cylinders! Those pistons must the tiny <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Southeast Crew Board [Re: Mad_Scientist] #758333
10/29/06 10:13 PM
10/29/06 10:13 PM
fasteddy  Offline
Helen , GA *****
You want a bad looking GroupB, look at a Lancia Stratos.
I was also fond of BRM H16 engines - two flat 8's with the cranks geared together, ginned up when they went from 1.5 to 3.0l in F1. Talk about Rube Goldberg. IIRC, the Cosworth v8's ate it up....
Moderated by  52degrees, Adam F, Axe Man, kewlynx
Page Time: 0.013s Queries: 16 (0.005s) Memory: 1.0816 MB (Peak: 1.2138 MB) Zlib disabled. Server Time: 2018-06-24 08:40:54 UTC
