66
guests, and 3
Posts1,081,775
Re: Triple Diamond Logo
[Re: PHIL_]
#766226
04/05/07 06:05 AM
MB619578-2
red colour plastic for grill
Front ball joints
[Re: redbull]
#766227
04/06/07 11:46 PM
Hi Guys, Front right ball Joints for a '92 Pajero LWB. Rock Auto parts: Upper right side K9753 Lower left side K9755
1991 JDM Pajero 2.5TD 4 Door
Re: Front ball joints
[Re: Rooman]
#766228
05/24/07 01:42 AM
[color:"red"] Contitech Timing belt kit part #'s [/color]
Timing belt kit # - CT517K1 Balance shaft belt kit # - CT714K1
each kit comes with the belt, and spring tensioner/pulley
[Re: torquemonster]
#766229
08/09/07 05:19 AM
Front brake pads for a 91 Pajero
NAPA AE7241M
although the part number is for metalic pads it will be easy for a shop to cross reference off this number. I changed the rear pads about 6 months ago and just used the spec pads for a 92 montero.
Cheers
Re: Pajero 4D56 Parts Cross-Reference List!
[Re: PHIL_]
#766230
08/23/07 06:06 AM
[Re: VERRELLI]
#766231
08/23/07 03:26 PM
Rotor Part #'s NAPA 4885926 if equiped with single piston calipers 4886687 early GenII with dual piston calipers 4886690 later GenII no dimensional difference, other than discard specification (minimum thickness) May have something to do with ABS availability, not sure.
Caliper Part #'s NAPA 14263069 L single piston 14263070 R " " 14264009 L dual piston 14264010 R " " These 2 #'s are also a good brake upgrade if you have the single piston's up front. They come with the brackets to direct swap, as well as the pads.
Recommended Tranny fluid is 3 diamond from the Stealer, however, I've used Valvoline Max-Life ATF with no issues. Let me know if any more #'s are needed, I'm bored at work today *YAWN* <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: hazy_daze]
#766232
08/24/07 08:05 PM
No difference with front and rear?
[Re: redbull]
#766233
08/24/07 09:34 PM
NAPA #'s Rear rotors 4886378
Rear Calipers 14264011 Left Rear 14264012 Right Rear
Pads CMX7447
Hope it helps <img src="/forums/images/graemlins/cheers.gif" alt="" />
BTW, these #'s are for 92 US-spec Montero's, which will be the same on ya'll's 91+ Pajero's <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: PHIL_]
#766234
10/03/07 01:24 AM
In order to keep this particular thread as useful and uncluttered as possible, I would urge all to re-read the guidelines at the top, re-referenced here: -Try to refrain from chat/conversation in this thread - if you need to comment, make a separate post. -If someone has already posted with a part number, and you have another number to add for the same part, PM me, and I'll edit/add it to their post (since your edit priveleges on your own thread expires after a short time). This will keep the part types together. -Don't post your cross-ref number unless you have either used it, or have it on reliable info, i.e. Mitsubishi's CAPS program, etc -Try to include the retailer where the part is available, if applicable. -Turn OFF your signature PLEASE (just for this thread only)
signature is on by default: please turn it off in this thread
The format we will use is:
Part name:
Part Brand and Number (retailers name) If everyone doesn't follow this, the thread will eventually get mired down in offshoots and questions, when the idea of it is to keep it short and simple, so if you're looking for something, you can find it quickly. If you're looking for a number that's not here, post it as a separate question. Once you find it, and try it, post your numbers on this thread, so others can benefit. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks Phil
Pitman Arm
[Re: PHIL_]
#766235
11/12/07 07:29 AM
Pitman Arm
Moog K9752 (as spec'ed for LHD 92 Montero): Auto Parts Plus
