60
Cargo Deck
#770069
12/06/06 02:46 PM
Can anyone point me in the right direction as to where I can get some replacement flooring for my Trooper? Ii need to repair the cargo deck and the drivers side floor under my seat. Any help will be appreciated.
1986 Trooper  Old age and treachery will beat youth and endurance any day. Squidman
Re: Cargo Deck
[Re: amerkinsquid]
#770070
12/06/06 09:32 PM
are you talking about sheet metal repair? if so, you're not going to find any premade tins. You'd best get to your local metal yard, grab some sheet and starting bend/forming. This kind of repair is usually custom.
If carpeting is what you want, you'll likely be confined to OEM parts suppliers... or, just rip it all out and get the tube spray'd with truck bed liner.
-Rob
Re: Cargo Deck
[Re: RobG]
#770071
12/07/06 04:57 PM
I had to replace the cargo floor around the interior wheel wells. I just used 20guage steel. I cut out the rusted portion. Laid it on the steel and traced it out. Cut that out and tacked it into place. Welded it all around. Ground it and painted it. You would never know it was there. Its relatively easy if its flat. If it's curved you will get to test your metal bending skills. Good Luck Lucas
86 Trooper II Stock except for the Rust and dents that came with it. Restoration while being a daily Driver is in progress. Completed so Far-Front Brakes, Rear Brakes, Frame restoration, 1 1/2" lift shackles, custom front and rear bumpers
Re: Cargo Deck
[Re: amerkinsquid]
#770073
12/08/06 01:13 AM
THOSE PANELS FOR THE REAR FLOOR WERE AVAILABLE THE LEFT REAR WAS 48.00 AND THE RT SIDE WAS 35.00 BUT THE LARGE CENTER SECTION WAS 351.00
894495 5841 LFT 894188 7282 RT 894188 2262 CENT//
JERRY
