75
Posts1,081,743
Re: 10-Bolt Aussie Lockers Available @ Independet4x
[Re: islandracer]
#778757
02/12/07 10:01 PM
Yup, still a few things to get used to but, I think I'm adjusting fairly well... Since I'm driving another Zu I think I'll be ok! <img src="/forums/images/graemlins/notooth.gif" alt="" /> Welcome to Texas! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Richard <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Richard Saylor]
#778758
02/16/07 04:11 AM
I wonder if one of these would fit in the case of those nonstandard 98 Amigo 4.77's? Seems like a reasonable chance. But then again, this type of locker in a front application probably isnt a real good idea. Andy
#778759
02/16/07 04:17 AM
I wonder if one of these would fit in the case of those nonstandard 98 Amigo 4.77's? I was wondering that exact thing <img src="/forums/images/graemlins/confused.gif" alt="" /> I'm getting rid of my 98 Amigo 4.77's, but I also happen to have a spare carrier from the same application. It's worth a try. You can have it Matt, but you have to come to Uwharrie to pick it up <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
1995 Passport - TH700R4 - Twin-sticked Dana300 w/tera 4:1 - Leaf sprung SAS w/Dana 60/14BFF - 38.5x11 Boggers - DOR bumper w/ MM SE9500
[Re: Starchild]
#778760
02/17/07 04:43 PM
deal..... <img src="/forums/images/graemlins/smile.gif" alt="" />
'93 RS 3.2L - DD/trail build '97 7.3L Powerstroke - tow rig '71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build Owner: http://www.INDEPENDENT4x.comm-f 9am-6pm EST. 804-550-0480
[Re: matthew]
#778761
02/18/07 04:15 AM
Nope, they won't fit the odd ball 98 carrier. I tried. The opening is physically too small to get the unit in where the spider gears had been. Heres a pic of the size difference between my '98 Amigo "odd-ball carier" and the '99 Trooper part I used for the install. The difference is as much as it looks. Trooper on the left, Amigo on the right ![[Linked Image]](http://i114.photobucket.com/albums/n280/muskyamigo/carriersize.jpg) One thing I am curious about though. It looks like the SOTF front ends are the same as the non SOTF units, and they just bolted the SOTF unit on to the end of the old housing. anyone know for sure? -Mike
Mike Walter '98 Amigo well used '94 Rodeo in need of help '99 Ram CTD for hauling feather pillows '01 unheated shop
[Re: muskyamigo]
#778762
02/19/07 01:50 AM
Heres a pic of the size difference between my '98 Amigo "odd-ball carier" and the '99 Trooper part I used for the install. The difference is as much as it looks. Trooper on the left, Amigo on the right Well, it was worth a try. Were you able to use the standard carrier with the gears from the '98? Still coming to Uwharrie Matt? <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
[Re: Starchild]
#778763
02/19/07 03:41 AM
Honestly, I didn't try. It was easy enough to find a front third member with the correct gears in it, so I use that and all of the parts that came with it (minus the odd TOD pinion flange)
From what I recall, I don't believe the 98 gears fit anything but the 98 third member.
Also I couldn't fit the standard third member in the 98 housing.
oh yeah, the cross shaft was also considerably smaller in the 98 differential.
-Mike
[Re: muskyamigo]
#778764
03/12/07 03:31 AM
so where are all the 4x4wire guys who wanted Lockers?????
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
we are about 1/2 way through the production run.......if you want one of these in your rig....GET YOUR ORDER IN!!!
12 bolts are pushing toward production......pretty excited about this one.... we have a good list of names going. Just call to get your name on there if you want the rear locker.
-matt
[Re: matthew]
#778765
03/12/07 04:52 AM
Right here, BUT... The Trooper is MIA, and the ex has the 4wd.. so.. no need... Chase
Chase
[Re: chasespeed]
#778766
03/13/07 12:13 AM
Matt: I'm in for a 12 bolt locker. I gave Bansil my welded and picked up an open from Jerry L. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Mark
Mark-95Trooper,fr LockRight,rr LSD,5spd,TeraLow,Indy tierods&QD sways,CO2, RS9000Xs,OME912&2.5"spacers,1"BL,ARB w/Warn M8000,OBT rear bumper&sliders. Pics indy4x
