Rebuild a Power Steering Pump
by MarkG. 02/17/19 03:55 AM
Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
by ATTILA. 02/12/19 10:16 PM
by rascott. 02/11/19 04:12 AM
Upgrade City
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
by Crops. 01/30/19 08:17 PM
0 registered members (), 122 guests, and 2 spiders.
Topics137,971
Posts1,079,919
Members14,882
Me thinking out loud #789075
02/13/07 07:09 AM
02/13/07 07:09 AM
SuperSwamper  Offline OP
North Carolina
OK, I have been thinking about welding the spider gears in my differential, And I have been thinking, instead of welding it solid, could you weld the gap between two teeth solid, and kinda achieve a locked differential, but it still able to move forward or backward a little bit, but only to the welded spot, and then be locked...
Just me thinking, just wondering if that would work, or am I better off if I was to weld it solid...
Thanks for any thoughts on the matter,
Matt
PICTURES OF MY 1986 ISUZU TROOPER PROJECThttp://www.cardomain.com/ride/2524435/1
Re: Me thinking out loud [Re: SuperSwamper] #789076
02/13/07 07:29 AM
02/13/07 07:29 AM
onebadtrooper  Offline
Mansfield Texas
It has been done before but I wouldn't. I'd just weld it solid. 1 it would be alot stronger and 2 you'd know for sure how it will act.
89 trooper, tera low t-case gears,5.38's, 3" indy4xsus lift3"body lift,safari snorkle,warn winch,custom bull bar,custom rock sliders,warn hubs,35x13.50r15,custom rear bumper trooper pics
Re: Me thinking out loud [Re: onebadtrooper] #789077
02/13/07 08:15 AM
02/13/07 08:15 AM
North Carolina
Ok, Thanks..
I was just wonderig if it is possible...
Matt
Re: Me thinking out loud [Re: SuperSwamper] #789078
02/13/07 02:40 PM
02/13/07 02:40 PM
RobG  Offline
Winston-Salem, NC, USA
welding the spider gears, but leaving a little play in them is a way bad idea. With the forces involved, it would take no time at all for that little play to grow into a full blown ka-boom! I've seen this happen in 14bff's where the welds weren't sufficient (its common practice to weld only the gears in this axle).
some will weld all 4 spiders to each other (solidly), and call it good there. However, it doesn't take much more effort to plate the center and the extra strength this affords is well worth it IMO.
be careful... if you're wrong with what you do here, you risk trashing your entire R&P with the shrapnel.
-Rob
Re: Me thinking out loud [Re: RobG] #789079
02/13/07 07:33 PM
02/13/07 07:33 PM
North Carolina
Thanks for the warning, I thought it might not work to well, Cause I think over time the gears would grind the weld into little chunks, or maybe even chip the teeth, and then the chunks would probably cause some sort of problem...
If I were to weld the rear solid, does it affect it much on pavement?
Thanks,
Matt
Re: Me thinking out loud [Re: SuperSwamper] #789080
02/13/07 08:00 PM
02/13/07 08:00 PM
RobG  Offline
its mostly going to effect slow, tight parking lot manevors. If you drive stick, it will likely change your timing of when you push in the clutch. You'll make some churping noises and cause a little extra tire wear and put some extra stress on your axle components. But all and all, its not too bad, just don't expect your driving style to remain the same.
If you don't wanna go that far, pay attention to the 12-bolt drop in lockers Matt @ Indy4x is getting made up. You'll get better road characteristics than welding without the price tag of an ARB.
-Rob
Re: Me thinking out loud [Re: RobG] #789081
02/13/07 08:16 PM
02/13/07 08:16 PM
North Carolina
OK, thanks..
I've been thinking about the aussie lockers, I would rather pay for one of those than pay twice that much for an arb...
I might just have to save up, and get the lift kit I want, and get an aussie locker at the same time...
Thanks again,
Matt
Re: Me thinking out loud [Re: RobG] #789082
02/13/07 08:50 PM
02/13/07 08:50 PM
Richard Saylor  Offline
Lockhart, TX *****
He should have a 10 bolt rear in the 86. Matt's already got those out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard <img src="/forums/images/graemlins/patriot.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Had an 89 Isuzu Trooper w/ 3.4 V6
01 Toyota Tundra SR5 V8 4Door Access Cab
http://community.webshots.com/user/rsayloriii
Page Time: 0.011s Queries: 15 (0.004s) Memory: 1.0294 MB (Peak: 1.1440 MB) Zlib disabled. Server Time: 2019-02-17 13:40:28 UTC
