80
guests, and 3
Jeep Just Died during driving and will not re-start
#790571
02/18/07 10:36 PM
My problem went to the next level. I was driving last night and it just died. It still turns over but Im getting no spark? I replaced the Coil thinking that was it but I still do not get spark through the coil. All the Jeep does is turn over like the coil wire is disconnected?
Re: Jeep Just Died during driving and will not re-start
[Re: josephelk]
#790572
02/19/07 12:20 AM
Prolly the sparkbox under the wiper fluid container... could be the PICKUP in the dist. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
OHHHH now I see the 4.0! Yikes! How bout the cps?
[Re: BigJim]
#790573
02/19/07 12:26 AM
What is a sparkbox? Would I still get spark from my coil if it had anything to do with the distributor?
[Re: josephelk]
#790574
02/19/07 01:12 AM
What year. Does it have fuel injection , the Crank POSITION sensor at the rear of the crank will cause a no spark
[Re: CLARK]
#790575
02/20/07 04:20 AM
It was a 30AMP fuse for the engine controller. Was that what you meant BigJim when you mentioned the sparkbox?
I had the 4.2L that was in my Wrangler originally all figured out so now I get to figure out all the little problems with the 4.0L, still no regrets with the 4.0. I have gained 7 miles per gallon and about 70HP with swapping the two engines.
Thanks for all the help.
Josephelk
