80
guests, and 3
Blown 2.5L. motor. I need help.
#790692
02/19/07 10:35 AM
Today I spent my third day in my (new to me)"95"Jeep Wrangler driving in the dunes.I know it's only a 4 cyl. motor ,but the dunes here in Oregon keep calling me to JUMP them, and I did.......until the engine started making a horrible knocking sound and lost all strength to jump or drive anymore. My question is do I replace the motor with a rebuilt 2.5L. or can I put a 4.0L.in its place without having to replace other parts? Any advice will help, Thanx
Re: Blown 2.5L. motor. I need help.
#790693
02/19/07 05:33 PM
Try the jeep section of the board, just go to main index and look for Jeep Tech <img src="/forums/images/graemlins/cheers.gif" alt="" /> Did you say jump <img src="/forums/images/graemlins/smile.gif" alt="" /> ![[Linked Image]](http://www.lesjackson.com/pb/lesair.jpg)
98 Montero with cold weather package 96 Toyota Land Cruiser, fully locked Mall Machine :-)
#790694
02/20/07 02:53 AM
BEFORE you go nuts with this get under it and look at the oil pan!!! You just might have pushed the front axel into the oil pan and the crank is beating on it! I bought a 89 real cheap once that had that going on... Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
#790695
02/20/07 05:09 AM
If you decide to go with the 4.0 you will need to replace not only the engine but the transmission, wiring harness, and the list goes on. I think you might be able to reuse your gas tank and fuel pump because you started out with a fuel injected engine. I did a 4.0 swap in my 89YJ that had the 4.2 carbureted engine and it wasn't that difficult. I just found myself a $600.00 wrecked XJ and pretty much used everything from it (except for the fuel tank and sending unit that I found at a local junk yard). If you do decide to do the swap you will be really happy with extra HP gain with the 4.0. I think youre still an OBDI with the 1995 or earlier? Im sure someone will correct me if its not. Try this website for some info also. http://www.cjoffroad.com/forums/topic.asp?TOPIC_ID=6408&SearchTerms=The,big,secret,is,out,-,wiring,OBDI Good luck
[Re: josephelk]
#790696
02/21/07 04:59 PM
To OP:
Have u tried trouble shooting and diagnosing what the heck the problem is? Have you checked compression? Did u run it out of fluids (i.e. oil, anti, etc..)? What is the matter with the original?
C. <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: cjensen]
#790697
02/21/07 05:07 PM
hey there....
didnt i give you a card at the top of spinreel?
have fun!
i've got a couple slideshows from our trip.
drop me a line if you'd like to see them.
