127
Topics138,177
Posts1,081,002
Re: 4:22 gear set inquiry
[Re: Dan1171]
#798826
03/21/07 02:26 PM
The gear ratio is listed on the data plate under the hood on the firewall.
Cheers, Charlie If It ain't broke, Modify it! 87 Montero turbo Converted back in 1989 95 Montero SR 3.8 DOHC First one? 93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed Will a 94 Macrocab Twin turbo with a 6 speed be next?
[Re: rxinhed]
#798827
03/21/07 06:13 PM
Oscar,
At the Pick-n-Pull in Roseville, NE of Sacramento, there are 3 4x4 Mistu pickups between 88 and 91, all 4 cylinder models. On Craigslist Stockton and Sacramento, there are currently 2 trucks of that age, one in Sonora for $300 and another in Chico for $500.
If you need some 4.625 (after all) gear sets, I have plenty of those around, same with the local yards. ROAD TRIP ! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Guess this weekend will not be good as its been raining but will try anyways to make it out to the Roseville Pick-N-Pull. And YES by general rule all 4x4 M-Max had the 4:22's But can anyone confirm if the 2.4L and V6 4x4 M-max had the same diff set-up ( 8" front and 9" rear ) Never pulled a front diff out completelly as I need the pinion gear as well, so rather do the rear <img src="/forums/images/graemlins/smile.gif" alt="" /> Thanks for the tip/lead rxinhed But still interested in a set if anyone has them already out. Oscar
[color:"red"]Have a ROTTEN day ![/color] <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Dan1171]
#798828
03/21/07 07:19 PM
I have an 85 monty 2.6 manual, and a 3.0 auto, that I am parting out, but I don't know what gears they have. I never drove the 2.6, but I have the 3.0 and runs good. How would I find out the size and gear ratio... Hello Dan1171 Bud you you confirm you have the 4:22's in the 8" diff in EITHER one of those you have let me know please. Please e-mail me at ( oscar-the-grouch@sbcglobal.net ) Thanks Oscar
[Re: OscarTheGrouch]
#798829
03/21/07 07:34 PM
My 94 V6 Max is 8&9" 4.22s. The 2.4 Max I have is 2wd, I never looked at the rear axle. When it comes back into site from being under the snow I can take a look. I can see the top of the cab today.
#798830
03/21/07 08:00 PM
No problem. I will look this afternoon when I get home and let you know in the morning.
[Re: OldColt]
#798831
03/21/07 08:47 PM
My 94 V6 Max is 8&9" 4.22s. The 2.4 Max I have is 2wd, I never looked at the rear axle. When it comes back into site from being under the snow I can take a look. I can see the top of the cab today. If its a 2WD then its got a 8" rear. I believe, almost 100% sure that ALL 2WD Max's came standard with 3:90's. Not sure if there were any 2.4L 4x4 Max's though ? And WOW the CAB ! Gee I am practically sweating bullets here in Cali today. No problem. I will look this afternoon when I get home and let you know in the morning. Sweet ! Thanks Bud oscar
[Re: Angelo]
#798832
03/22/07 01:28 AM
Well, mine isnt a 3.0, but I will have 4.22 gears frt & rear to sell in a week if you are interested. It will be out of a 3.5, 1999 Montero. Email me @ APKouts@aol.com or just post up. Good luck, Angelo Angelo, you should have 4.272 gears. I know it's a minor distinction but it may be of interest.
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
[Re: OldColt]
#798833
03/22/07 12:41 PM
I couldn't find a data plate on the firewall. Maybe I am just looking in the wrong location. The only one I found didn't not have that information on it.
[Re: Dan1171]
#798834
03/22/07 04:50 PM
My '97 has 4.272 gears. DavidG I remember you saying your SR had the same. What Gen2 SR trucks had the 4.63 then? Was that the 3.0? I guess they went to 4.272 with the 3.5...
[Re: Mad_Scientist]
#798835
03/22/07 06:35 PM
My '97 has 4.272 gears. DavidG I remember you saying your SR had the same. What Gen2 SR trucks had the 4.63 then? Was that the 3.0? I guess they went to 4.272 with the 3.5... Correct, I have 4.272. They went to the 4.272 with the SOHC (97+) 3.5. The earlier DOHC 3.5 had the 'better' gears.
1997 Montero SR
