80
guests, and 3
remember that noise I thought was an injector.....
#803022
04/06/07 12:54 AM
It turns out it was a camshaft journal wearing down. I am going to replace my cam shaft(s). Is there anything want to know or anything special I want to do before I get started?
1993 4Runner SR-5 4WD V-6 Auto Trans 1990 Pick-up (Hilux) 2WD SR-5 V-6 Auto Trans
Re: remember that noise I thought was an injector.....
[Re: irsean]
#803023
04/06/07 02:59 AM
I just pulled the head covers and found a "tweaked" shim lying in the oil reservoir. Also the corresponding cam journal is worn down.
[Re: irsean]
#803024
04/06/07 02:59 AM
The other cam looks good but, should I replace it as well?
[Re: irsean]
#803025
04/06/07 03:01 AM
Now I just need a tool that will hold the cam sprockets while I get them loose.
[Re: irsean]
#803026
04/06/07 03:19 AM
Sean, I don't know if you're aware, but there is a 93 FSM sticky'd at the top of this section for your guidance, esp in the inspection phase.
[Re: kewlynx]
#803027
04/06/07 03:46 AM
I have poured over that thanks. Just wondering if there's anything else anyone can add. It's going pretty well. I think I will replace both cams since I have them exposed.
[Re: irsean]
#803028
04/06/07 04:03 AM
I guess one question I would have is whether I should buy an OEM set or aftermarket and if so, what would be best for gas milage (product suggestions welcome at this point.)
[Re: irsean]
#803029
04/06/07 06:52 AM
Get one of the cams sets from sea2sky.com.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Rauch_Off_Road]
#803030
04/06/07 07:24 AM
that address doesn't work.
[Re: irsean]
#803031
04/06/07 07:37 AM
Now I just need a tool that will hold the cam sprockets while I get them loose. To break the cam gear bolt lose you need either an 1-1/8" or1-1/4" wrench, and a 2x4 about 18 inches long. For the passenger side cam gear place the 2x4 on end on top of the upper arm and brace the wrench against it, for the driver's side use the top of the engine, to install reverse the procedure. Be careful when breaking the cam gear lose, they are prone to breaking
