Introduction & New Raider
by Bigshankhank. 01/21/19 07:04 PM
My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 128 guests, and 1 spider.
Topics137,963
Posts1,079,874
Members14,875
dana 20 #817685
06/09/07 07:42 AM
06/09/07 07:42 AM
J
jruth69  Offline OP
Colorado, Crested Butte
i have a stock 1977 cj-7 three speed. I just found a newer/rebuilt engine with a 5speed transmission i was wondering if anyone knew if it would fit or would i have to buy a transfer case adapter <img src="/forums/images/graemlins/confused.gif" alt="" />
amc 20 *DELETED* [Re: jruth69] #817686
06/09/07 05:30 PM
06/09/07 05:30 PM
J
jruth69  Offline OP
Post deleted by jruth69
Re: amc 20 [Re: jruth69] #817687
06/09/07 08:26 PM
06/09/07 08:26 PM
BobRowe  Offline
Southeast Michigan
I assunme you mean a Dana 20 transfer case? The AMC 20 is a rear axle.
Fit depends on the particular transmission you have. I suggest that you find out the designation fo the particular tranny you're talking about, and then call Advanced Adapters and find out if it will fit direct, or if you will need an adapter.
Re: amc 20 [Re: BobRowe] #817688
06/10/07 04:15 PM
06/10/07 04:15 PM
S
superdawg  Offline
Denver, Colorado
Dana 20 t case has the same bolt pattern as a Dana 18 and scout dana 300 case.
D20 is a very good strong t case, but lacks low enough ratio in low range.
The trans you have (provided it is out of a later model CJ) will work with a Jeep dana 300, but not your d20.
The biggest problem is that the T150 tranny you have is stronger than the 5 speed (t-5) anyday. so...the best solution for reliabe strong upgrading is to go with a t-18 4 speed, and keep your d 20 case or really upgrade and do a t 18 with a d300 behind that. Call Mitch at RMH Transmissions 303-808-1268 he can fix you up.
SD
Re: amc 20 [Re: superdawg] #817689
06/10/07 07:35 PM
06/10/07 07:35 PM
J
jruth69  Offline OP
yea well i think im gonna get it anyway cause my motor is shot almost runs like ***** nbut yea i got the offroad shop here to order me a dana 300
Re: amc 20 [Re: jruth69] #817690
06/11/07 12:29 AM
06/11/07 12:29 AM
S
superdawg  Offline
Denver, Colorado
The t5 is junk, beware. This is the time to upgrade to a better tranny. Afterall you will be getting new driveshafts to go with the t5, sooner or later you will be doing it again.
SD
Re: amc 20 [Re: superdawg] #817691
06/11/07 08:15 AM
06/11/07 08:15 AM
J
jruth69  Offline OP
yea i know nbut i am gonna try it with the three speed tranny then try the 5 speed to see wat i like best <img src="/forums/images/graemlins/mrt.gif" alt="" />
Moderated by  4x4Wire
Page Time: 0.011s Queries: 15 (0.004s) Memory: 1.0334 MB (Peak: 1.1434 MB) Zlib disabled. Server Time: 2019-01-22 01:40:39 UTC
