96
guests, and 4
Posts1,080,940
LSPV Rebolting Idea-Any reason why I shouldn't do this?
#820641
06/22/07 05:55 AM
I'm halfway through putting a 3 1/2" lift on my truck (3" springs, 1" over stock shackles) and I'm to the point of dealing with the LSPV. I was thinking of doing the arm/turnbuckle trick, but as I was under there today I noticed that the top mounting bolts on the LSPV are about 3" from the bottom bolts-could I just reposition the LSPV by bolting the top mounting holes into the bottom frame holes? Seems like this would avoid having to fab or buy a new bracket. Would there be any danger in having 2 bolts holding it in instead of 4? I can't think that it would be under much stress.
85 Pickup, Desert tan spray job, 3" Rough Country lift, Marlin shackles+bumper, Chebby igniter, 33x10.5" BFG's
Re: LSPV Rebolting Idea-Any reason why I shouldn't do this?
[Re: Multimetal]
#820642
06/22/07 07:38 AM
I think it sees a fair bit of stress. Mine was actually limiting droop on my rear axle before I cut it off and zip tied it up.
[Re: cam01]
#820643
06/22/07 03:25 PM
Toyota Section Staffer
I found Front Range Off Road Fabrication's manual proportioning valve (same as Summit's, but with metric adapters) to be lightyears more effective than the LSPV. Solves several problems!
And yeah, Toyota put 4 bolts on there for real reasons.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#820644
06/22/07 03:50 PM
I second getting the summit proportioning valve. Huge improvement over stock!
-Scerb
[Re: Multimetal]
#820645
06/22/07 06:28 PM
I'm halfway through putting a 3 1/2" lift on my truck (3" springs, 1" over stock shackles) and I'm to the point of dealing with the LSPV. I was thinking of doing the arm/turnbuckle trick, but as I was under there today I noticed that the top mounting bolts on the LSPV are about 3" from the bottom bolts-could I just reposition the LSPV by bolting the top mounting holes into the bottom frame holes? Seems like this would avoid having to fab or buy a new bracket. Would there be any danger in having 2 bolts holding it in instead of 4? I can't think that it would be under much stress. How hard is it to fab an extension, it is a flat piece of stock with a few holes drilled in it.
"Serenity through Sobriety"
[Re: OOP'S]
#820646
06/23/07 12:37 AM
Try welding threaded rod onto the axle mounting side.
[Re: Vanishing_Point]
#820647
06/23/07 01:25 AM
Thanks for the advice guys, guess I'll fab up a plate or try zip-tying it off. I want to replace it entirely, but it might be a while till I get a new valve!
