80
guests, and 3
Front Frame Brace
#822176
07/01/07 03:14 AM
Just a quick informal poll if you will. Do you think a front frame brace, like the one linked to below is a good investment prior to installing a winch and aftermarket bumper? Have some steel laying around, and thought if it was a good idea, I'd whip one up. http://frontrangeoffroadfab.com/nfo...;osCsid=79f2ba1ab35bfadc065ef840a0766396
84 Ext. Cab Pickup.
Re: Front Frame Brace
[Re: Buck]
#822177
07/01/07 03:45 AM
"Serenity through Sobriety"
[Re: OOP'S]
#822178
07/01/07 06:30 AM
Yeah, I thought so too, so I went ahead and made one. Don't think that stock brace could hold up to too much winching. <img src="/forums/images/graemlins/smile.gif" alt="" />
84 Ext. Cab Pickup.
[Re: Buck]
#822179
07/01/07 09:40 AM
No it wouldn't, but if possible, you're primary mounts for whatever winch bumper you're using should be the 2 tow hook bolts under each front frame leg. That's the strongest point.
Of course, those of us with SAS trucks, don't get to use those bolt holes, so we have to improvise, but if you have access to them, I would use them.
[Re: Brian894X4]
#822180
07/01/07 03:38 PM
[Re: missouriman]
#822181
07/02/07 04:11 AM
I made one as well but its a little different in that it ties in behind the x-member down the frame rail. I plated the top and bottom as well as the face. ![[Linked Image]](http://img.photobucket.com/albums/v229/ganoid/100_0502.jpg)
90 Xcab V6 3.0 Rebuilt/Balanced P/P w/OS valves Downey Hdrs,Jacobs Ign 5.29's,Tru Trac+Lockright 4"TG SAS+Rear Kit on 35's (DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />) www.performancecylinderheads.com
[Re: Ganoid]
#822182
07/02/07 02:23 PM
I like that.. but I don't have a body lift.
