89 GEN1 LWB Headlight Washer Pump Rebuild
by chadzeilenga. 06/24/18 06:13 AM
1989 LWB A/T Temp Light
by chadzeilenga. 06/24/18 05:36 AM
GEN1 LWB Radio reception
by chadzeilenga. 06/24/18 05:34 AM
by rascott. 06/20/18 12:47 PM
Bumper?
by TOASTY. 06/20/18 02:59 AM
Instrument Cluster Fuse
by rxinhed. 06/17/18 04:50 PM
Winch bumper
Gen 2 seat options
My '88
4x4Wire YJ
0 registered members (), 92 guests, and 3 spiders.
Topics137,876
Posts1,079,486
Members14,783
Broken rear leaf spring #830522
08/13/07 01:15 AM
08/13/07 01:15 AM
F
FarmerTed  Offline OP
Utah
I noticed today that the third leaf down on the passanger rear of my 94 4x4 is broken. Is this uncommen? Where can I get a replacement? And do I have to replace the whole spring pack or can I just change out the broken leaf. No clue how long it's been this way.
1994 4x4 22RE
Re: Broken rear leaf spring [Re: FarmerTed] #830523
08/13/07 01:17 AM
08/13/07 01:17 AM
G
Greg_Canada  Offline
Toronto, Canada
My cousins 88' did that too.
You can use a junkyard leaf, or jcwhitney sells stock replacements.
89 4Runner
Re: Broken rear leaf spring [Re: Greg_Canada] #830524
08/13/07 02:21 AM
08/13/07 02:21 AM
stock87  Offline
Placerville, CA
Anyone here tried them? I'm considering them for a cheap & easy sag fix.
Re: Broken rear leaf spring [Re: stock87] #830525
08/13/07 02:57 AM
08/13/07 02:57 AM
4Crawler  Offline
N. California. USA *****
I've seen a few folks on YotaTech use them. Supposed to work fairly well.
Re: Broken rear leaf spring [Re: stock87] #830526
08/13/07 07:46 AM
08/13/07 07:46 AM
missouriman  Offline
Black Hills of South Dakota
junk yard, you pull it should be cheap.
Re: Broken rear leaf spring [Re: FarmerTed] #830527
08/13/07 07:48 AM
08/13/07 07:48 AM
Snowtoy  Offline
Grass Valley, CA
Check with a local spring shop if you have one, or are close to an area that does. One spring shouldn't be to much if you do the work. Or as mentioned grab a set from a wrecking yard, shouldn't be more than about $30/set.
Re: Broken rear leaf spring [Re: Snowtoy] #830528
08/13/07 11:00 PM
08/13/07 11:00 PM
Rauch_Off_Road  Offline
Manitoba, Canada
Why not look into a chevy spring swap?
(aka suprathepeg, aka Sean)
Re: Broken rear leaf spring [Re: Rauch_Off_Road] #830529
08/13/07 11:31 PM
08/13/07 11:31 PM
Scerb  Offline
boonies of NH
I ran jcwhittney springs for about 1.5yrs. Flexed about how a stock spring would, rode nice. I had no complaints
Re: Broken rear leaf spring [Re: Scerb] #830530
08/18/07 04:33 AM
08/18/07 04:33 AM
F
Utah
Dealer wants $120 for just the single leaf or $550 for the spring pack. JC Whitney want $130 for each spring pack. Im may give JCW a try, but I'm going to check the Pic N Pulls first. What year springs will match the 94's?
1994 4x4 22RE
Re: Broken rear leaf spring [Re: FarmerTed] #830531
08/18/07 05:14 AM
08/18/07 05:14 AM
OOP'S  Offline
Roseville, CA, Gateway to the ...
I broke the third leaf in an A-P pack once. Took a stock pack apart and took one of the leafs that was longer then the broken one. Lined up the center bolt hole on both and marked the longer leaf to the length of the broken leaf. Cut the excess off and put the A-P pack together. I thought it might lean a bit when I put it back on. It worked great, no lean, flexed great.
I think the rear springs on the 90-95 are the same.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Page Time: 0.017s Queries: 16 (0.009s) Memory: 1.0591 MB (Peak: 1.1903 MB) Zlib disabled. Server Time: 2018-06-24 12:29:31 UTC
