60
guests, and 3
Topics138,276
Posts1,081,746
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker
[Re: strawmyers]
#852533
01/13/08 03:29 PM
Sean is right. You cannot just swap the entire 3rd since the VX has a 4.30 ratio and trooper has a 4.56. You will need to swap the carrier only from an open 3rd into the VX 3rd. Once they are swapped, you will need to check backlash and engagement pattern.
Mark-95Trooper,fr LockRight,rr LSD,5spd,TeraLow,Indy tierods&QD sways,CO2, RS9000Xs,OME912&2.5"spacers,1"BL,ARB w/Warn M8000,OBT rear bumper&sliders. Pics indy4x
[Re: Wareagle]
#852534
01/14/08 03:01 AM
VX uses the same rear axle as the 92-97 trooper
you could also use this as an opportunity to do a gear swap.......you could get an open 4.56 rear 3rd and also swap in a front 4.56 10 bolt 3rd
lots of cool options for hte VX owners <img src="/forums/images/graemlins/wink.gif" alt="" />
'93 RS 3.2L - DD/trail build '97 7.3L Powerstroke - tow rig '71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build Owner: http://www.INDEPENDENT4x.comm-f 9am-6pm EST. 804-550-0480
[Re: matthew]
#852535
04/18/08 10:56 PM
Matt,
Awsome job i think it's great that you have a 12 bolt locker coming out as well as a 10 bolt and the 3.07 gear set's I'm definetly looking forward to ordering them.
- Jason
2004 GMC 1987 Samurai
Go Army
[Re: TrooperXS]
#852536
04/23/08 03:37 AM
all these products are out and shipping.
thanks for the props. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: matthew]
#852537
10/26/11 12:10 AM
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
