93
Topics138,278
Posts1,081,771
tire envy
#855930
12/30/07 12:17 AM
this truck belongs to a wrecker company in Orange TX. It was built to recover offroaders from the local pipelines and High Lines. ![[Linked Image]](http://i223.photobucket.com/albums/dd19/myjkrubicon/1228071027.jpg)
I would rather be tried by 12 than carried by 6
Re: tire envy
[Re: jkrubicon]
#855931
12/31/07 12:31 AM
What sort of terrain are they dealing with ??
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: tire envy
[Re: PartyTruck]
#855932
12/31/07 01:36 AM
Emagine the gear ratio. What do you think it is? I'll say somewhere in 8's <img src="/forums/images/graemlins/mrt.gif" alt="" />
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
Re: tire envy
[Re: jkrubicon]
#855933
01/01/08 02:23 AM
The trcuk was built to recover vehicles from pipelines and other remote locations.It has a factory 5.9L cummings engine. and sets on 5 1/2 ton military axles, with a 5 1/2 ton t-case. alot of the trucks in the area are running 38's or better. the terrain in this part of texas is mostley swampland. It is in the South East corner of Texas Bordering Laouisianna
Re: tire envy
[Re: jkrubicon]
#855934
01/01/08 03:52 AM
Those tires are a hellova lot taller than 38's!
Re: tire envy
[Re: BobRowe]
#855935
01/01/08 04:30 AM
I betcha they are closer to 58's than 38's.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: tire envy
[Re: BigJim]
#855936
01/01/08 02:10 PM
Hey Jim maybe you should start hanging tires on your living room wall and take the deer heads down. I bet those tires could be prize winners. You can call the amount of knobs, points. These tires could be a 36 point roller at 58"s. You can hang one over your mantle. <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: tire envy
[Re: reepersteve]
#855937
01/02/08 07:09 AM
I'm concerned about the tire rubbing the driver's head off at full stuff.
80 CJ-7. It runs
Re: tire envy
[Re: jstritec]
#855938
01/03/08 01:50 AM
I'm concerned about the tire rubbing the driver's head off at full stuff. <img src="/forums/images/graemlins/lol.gif" alt="" /> Good one, Josh! <img src="/forums/images/graemlins/kewl.gif" alt="" />
94 YJ, SOA, 2-1/2 Alcans, ARB-front, Detroit-Rear, 4.56:1 gears, Oasis Trailhead compressor, 4:1 Terra Lo, 37x12.50x15 SSR's, 8000 lb Ramsey, & etc.
Re: tire envy
[Re: jkrubicon]
#855939
01/03/08 05:36 PM
I was saying that most of the trucks in that area are running 38's or bigger. those are actually 63" according to the owner of the truck.
