Gen 1 rear locker ?
Mass Airflow unit questions.
Relay under console !
Topics138,146
Posts1,080,836
Members15,113
Manual Locking Hubs #866315 02/03/08 06:16 PM
S
scott473 Offline OP
For those of you wanting or needing to switch to the manual locking hubs don't be scared.
I have a 99 that had the vacuum activated hubs. In the matter of 10 minutes I was able to get my tools and have them swapped over.
The instructions were to skip straight to step 10. Step 10 in just installing the hubs. Obviously you have to uninstall the old ones.
Ok so
step 1 pop hub caps off
step 2 remove the 6 bolts holding the hubs on
step 3 pull old hubs off
step 4 slide new hubs on and align the 6 holes
step 5 install the 6 bolts torque to 25lbs or at least close
step 6 pop hood
step 7 unplug the white plug in front of master cylinder attached to vacuum canister.
step 8 Have fun your done.
Its literally that easy. so dont be afraid to do the swap.
Re: Manual Locking Hubs [Re: scott473] #866316 02/03/08 06:42 PM
jaybur Offline
if you can operate a ratchet, even if its your first time using a ratchet, you can do the manual hub swap. nothing to it
Sportage sold.........
Re: Manual Locking Hubs [Re: jaybur] #866317 02/04/08 09:00 PM
H
homerdog Offline
I cut the center of the hub caps out with a Dremel. You're either going to have to do that to access the locking hubs or run without hub caps.
2011 Kia Forte EX
PHP: 7.2.34 Page Time: 0.026s Queries: 15 (0.008s) Memory: 2.8288 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2020-10-26 04:35:26 UTC
