99
guests, and 4
Topics138,203
Posts1,081,254
[Re: Chris_Eichman]
#866538
04/12/08 04:46 PM
Body Lifts here: <img src="/forums/images/graemlins/kewl.gif" alt="" /> web page
[Re: jaybur]
#866539
04/15/08 03:56 AM
any body know how i should go about lifting a 2WD sporty, yes i said 2wd...
i just want to lift it about 2 inches, could i use spring spacers or is that only for 4wd.
let me know i need some serious advice
and please dont tell me to get a 4wd sporty, if that was possible at this moment in time than i would
[Re: mudz]
#866540
04/15/08 04:55 AM
The spring spacers are all the time. Send an email to upyourkia@yahoo.com He can help you out.
[Re: Chris_Eichman]
#866541
04/30/08 08:16 AM
Would someone like to hazard a guess as to how a Kia Sportage with a 4" suspension lift with tyres 235 75 15 would look.
[Re: BAZINGA]
#866542
04/30/08 02:26 PM
Not as good as it would with 31 10.50's!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Everet <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Everet]
#866543
04/30/08 03:44 PM
the 31x10.5 would look great, but i'm on a budget. as long as the 235 75 15's dont look stupid with the 4" lift
[Re: BAZINGA]
#866544
04/30/08 05:34 PM
I know with 205's and my lift it looks pretty lame. Check <a href="www.craigslist.com" target="_blank">CRAIGSLIST</a> off and on and you may find a good deal. If you want new, Schawb has some pretty good deals. Look at 30 9.50's as an option. Everet <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: BAZINGA]
#866545
05/06/08 04:31 PM
i like the look of the 235/75r15 i run. dont think they look bad at all. they actually measure at 29.25 dia. and 8.9 wide, so its not a huge amount smaller than 30x9.5. may not look as mean a 31x10.5 but looks a thousand times better than stock.
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
[Re: jaybur]
#866546
05/12/08 05:20 PM
what has happened to dave's rocksport gear page?
[Re: jaybur]
#866547
05/12/08 05:28 PM
TIRES:
235 75 15 is also a good choice if you are running a 2" lift. its a very common tire size, so there are many options and styles available. Fits on standard rims, no lift required, although some minor trimming of the underside of the front bumper will be needed (~0.5" x 6" strip)..."
where precisely do you need to trim and how major is it? will the trimming be noticed? I'm concered that I might stuff it up ('cause I dont know what to do)
