100
guests, and 9
Topics138,177
Posts1,081,002
[Re: BAZINGA]
#866548
05/13/08 06:08 AM
what has happened to dave's rocksport gear page? web page
[Re: jaybur]
#866549
05/16/08 03:52 AM
<img src="/forums/images/graemlins/notooth.gif" alt="" /> IAM TRYING TO GET ON DAVES ROCKSPORT GEAR WEBSITE AND CANNOT SEEM TO HAVE ANY LUCK. WANT TO FIND MORE OUT ABOUT THE 4" LIFT FOR A 2000 KIA SPORTAGE, WHERE TO GET ONE AND HOW MUCH,AND ALSO WONDERING DOES ANY ONE KNOW ANYTHING ABOUT THE 2 1/2" EIBACH COILSPRING LIFT. WONDERING IF I WILL HAVE TO ANY TRIMMING TO RUN 30X9.5X15.
[Re: Hydra747]
#866550
05/16/08 04:03 AM
try the "web page" in the post above <img src="/forums/images/graemlins/sleeping.gif" alt="" />
[Re: BAZINGA]
#866551
05/16/08 06:48 AM
try the "web page" in the post above <img src="/forums/images/graemlins/sleeping.gif" alt="" /> x2!
[Re: Hydra747]
#866552
05/16/08 09:31 PM
<img src="/forums/images/graemlins/notooth.gif" alt="" /> Dennis I was just wondering where you got the eibach 2 1/2 coil springs the 4x4 shop here said they could not find anyone who has them and I would like to find a set to start out with dont want to much of a lift,just enough 2 fit 30x9.5's on my sporty
[Re: doughboywanttoliftmykia]
#866553
05/16/08 10:43 PM
Just clicked on it and it is showing all the pics and descriptions. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Everet
[Re: Everet]
#866554
05/16/08 10:59 PM
yes finaly saw all the pics
#866555
05/20/08 12:49 AM
I bought my Eibach's way back in about June of 2000. They don't make them any more but I can make you spacers for about a 2 1/2" lift, email me at (upyourkia@yahoo.com)
[Re: jaybur]
#866556
07/15/08 02:30 AM
Ok.. So you can lift the car even 4" but:
1. what about the rear axle, would it not be under the wrong angle? 2. front half shafts, the same, if I make 2"extension on the strut my half shafts will be under the angle that could damage them. 3. drive shafts, not to short?
please give me answeres. I have already ordered higher springs, made on request.. and I have extensions for the struts ready, waiting for the springs to come...
should I be worried? <img src="/forums/images/graemlins/baby.gif" alt="" />
[Re: tonder]
#866557
07/15/08 04:07 AM
The rear axle will be off set a little, I have about 120,000 miles on my lift with no problems though. I still have the original C-V axles also. With 4 inches of lift I can't go down the freeway and 75 MPH with the hubs lock in, they start to vibrate about 45 or 50 but with all the wheelin Iv'e done they have held up well. If you look at your C-V axles stock the center line of the dif is lower than the center line of the hub. With a 2" lift the axles are at the same angle, just reversed. So in theory a 4" lift only increases the angle of a 2" lift. I have not had any problem with the rear drive shaft, with a 104" wheel base they are long enough.
Hope this helps, Dennis
