the cold start shuffle got me
Topics138,274
Posts1,081,733
Page 11 of 51 1 2 9 10 11 12 13 50 51
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866608 03/22/09 03:21 AM
I picked up a set of tires, BFG Long Trail on a set of Rims...took off the truck actually, now that truck is on logs.
Anyhow, I am now looking for flares or something inexpensive to put on now.
Any help on finding some flare material??
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: ChrisB] #866609 03/22/09 07:18 PM
DennisThompson Offline
The XJ springs could be to stiff for the rear of a light weight Sportage. I bet the Grand is almost twice as heavy in the back. Even the TJ springs don't compress as much and the sportage as the do on a TJ.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: ChrisB] #866610 03/22/09 07:24 PM
Will xj springs off a 96 grand cherokee fit?My brother just lifted his jeep and there laying around
Are the rears double pig tail? What is the unsprung height? What is the spring rate?
I can give you some info if you know these things.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866611 03/23/09 04:46 AM
ChrisB Offline
They are not double pig tail.Im sure they are to stiff anyways.scratch that idea. Still debating if i should get my warn manual's or lift first
01 Kia sportage,Removed front bumper,Warn manual hubs,
Make it Break it
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. #866612 03/23/09 06:28 PM
I believe that custom flares are no longer made for the Sportage.
A possible solution could be from JC Whitney .
I'm going to try theirs later this year. Will post it when the project is complete. I think Hydra found some that work.
If you find something, start a new post and include pictures.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866613 03/24/09 12:22 AM
BAZINGA Offline
Being the frugal person that I am, I purchased a plastic soak well and cut it into strips then screwed it to the underside of the guard.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet] #866614 03/24/09 11:42 AM
4
4runnernomore Offline
Hi,
Flares for the Sporty a real hard thing to find. I went through this process last year. I managed to find one of the last sets from a company in America. They were actually produced in Australia but I do not know which company made these. Here is a couple of piccies of the flairs
I tried to contact a company here in Aus who I thought may have made them http://www.bossproducts.net.au/about%20us.htm but I never recieved any replies to my emails. I was hoping that they may be able to make them or produce a wider set. This is the issue with the flairs they do not cover enough, especially the front ones for those who have gone the wide tyre route 31 x 10.5 and larger. I still have these flairs as I have not fitted them to my Sporty as yet. My direction has changed. I did try contacting all the manufactures I got hits on for Sporty Flairs including the one from England. Every one has stopped producing.
Perhaps my flairs could be used as a moulding to produce new ones, just a thought, if the market is there??
Cheers, Chris.
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: 4runnernomore] #866615 03/24/09 04:25 PM
Hydra747 Offline
CHECK THIS OUT:
web page
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Hydra747] #866616 03/25/09 02:38 AM
BAZINGA Offline
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur] #866617 03/31/09 06:14 PM
k120189 Offline
i would like to make a correction.
the steel wheels from the tracker have the same if not a little more backspacing. so they will work i just checked with a set i have.
PHP: 7.4.29 Page Time: 0.044s Queries: 16 (0.024s) Memory: 2.9383 MB (Peak: 3.1934 MB) Data Comp: Off Server Time: 2022-05-26 23:23:41 UTC
