74
guests, and 3
Topics138,274
Posts1,081,733
[Re: jaybur]
#866608
03/22/09 03:21 AM
I picked up a set of tires, BFG Long Trail on a set of Rims...took off the truck actually, now that truck is on logs. Anyhow, I am now looking for flares or something inexpensive to put on now. Any help on finding some flare material??
[Re: ChrisB]
#866609
03/22/09 07:18 PM
The XJ springs could be to stiff for the rear of a light weight Sportage. I bet the Grand is almost twice as heavy in the back. Even the TJ springs don't compress as much and the sportage as the do on a TJ.
[Re: ChrisB]
#866610
03/22/09 07:24 PM
Will xj springs off a 96 grand cherokee fit?My brother just lifted his jeep and there laying around Are the rears double pig tail? What is the unsprung height? What is the spring rate? I can give you some info if you know these things. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Everet]
#866611
03/23/09 04:46 AM
They are not double pig tail.Im sure they are to stiff anyways.scratch that idea. Still debating if i should get my warn manual's or lift first
01 Kia sportage,Removed front bumper,Warn manual hubs,
Make it Break it
#866612
03/23/09 06:28 PM
I picked up a set of tires, BFG Long Trail on a set of Rims...took off the truck actually, now that truck is on logs. Anyhow, I am now looking for flares or something inexpensive to put on now. Any help on finding some flare material?? I believe that custom flares are no longer made for the Sportage. A possible solution could be from JC Whitney . I'm going to try theirs later this year. Will post it when the project is complete. I think Hydra found some that work. If you find something, start a new post and include pictures. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Everet]
#866613
03/24/09 12:22 AM
Being the frugal person that I am, I purchased a plastic soak well and cut it into strips then screwed it to the underside of the guard.
[Re: Everet]
#866614
03/24/09 11:42 AM
I picked up a set of tires, BFG Long Trail on a set of Rims...took off the truck actually, now that truck is on logs. Anyhow, I am now looking for flares or something inexpensive to put on now. Any help on finding some flare material?? I believe that custom flares are no longer made for the Sportage. A possible solution could be from JC Whitney . I'm going to try theirs later this year. Will post it when the project is complete. I think Hydra found some that work. If you find something, start a new post and include pictures. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Hi, Flares for the Sporty a real hard thing to find. I went through this process last year. I managed to find one of the last sets from a company in America. They were actually produced in Australia but I do not know which company made these. Here is a couple of piccies of the flairs ![[Linked Image]](http://i217.photobucket.com/albums/cc190/4runnernomore/Kiaphotos006.jpg) ![[Linked Image]](http://i217.photobucket.com/albums/cc190/4runnernomore/Kiaphotos008.jpg) I tried to contact a company here in Aus who I thought may have made them http://www.bossproducts.net.au/about%20us.htm but I never recieved any replies to my emails. I was hoping that they may be able to make them or produce a wider set. This is the issue with the flairs they do not cover enough, especially the front ones for those who have gone the wide tyre route 31 x 10.5 and larger. I still have these flairs as I have not fitted them to my Sporty as yet. My direction has changed. I did try contacting all the manufactures I got hits on for Sporty Flairs including the one from England. Every one has stopped producing. Perhaps my flairs could be used as a moulding to produce new ones, just a thought, if the market is there?? Cheers, Chris.
[Re: 4runnernomore]
#866615
03/24/09 04:25 PM
CHECK THIS OUT: web page <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Hydra747]
#866616
03/25/09 02:38 AM
[Re: jaybur]
#866617
03/31/09 06:14 PM
i would like to make a correction. the steel wheels from the tracker have the same if not a little more backspacing. so they will work i just checked with a set i have.
