86
guests, and 4
Topics138,274
Posts1,081,733
[Re: jaybur]
#866618
04/02/09 06:12 PM
Hey guys, thnx for the input on the flares. I think I am going to find something myself to put on. Lots of options. Anyhow, I think I am gonna go with the UpYourKia Front Spacers, but I need to know what model of 1998 Rav4 do I get the shocks for that will fit my 2001 Kia Sportage. Also the Year and Model of TJ to get the springs from. I have been asked and don't feel to smart when asked, "What do you mean you don't know???". lol Just wanna get the right parts the first time here is all. Thanks Again guys.
#866619
04/03/09 11:19 AM
I wanted to get the rav4 shocks. got them home and discovered the bottom eyelet was the wrong size (too big i think). ended up going with kyb standard
[Re: BAZINGA]
#866620
04/03/09 01:12 PM
everet ships eyelets in his spacer kit
[Re: logansportage]
#866621
04/29/09 03:29 AM
It's due to the pan hard rod moving the axle. When you lift the Sportage the distance shortens due to the mount of the pan hard rod pulling the axle to the right.
As the axle articulates down you get rubbing on the left side. As it articulates up it moves back to center. The more lift you install the worse it gets.
Dave has an adjustable pan hard rod you can order, or you can build a bracket to relocate the pan hard rod down the same amount of lift you installed to relocate the axle back to center.
Logansportage <img src="/forums/images/graemlins/patriot.gif" alt="" /> What is this pan hard rod that I keep hearing about in the rear suspension, never heard that term before? Are you referring to the Transverse rod that goes side to side? I have to know so I can follow what everyone is talking about?? Hey Jaybur, you may want to edit the info regarding the 3" spacer lift? Correct me if i'm wrong but as i understand it a 2" spacer up front gets you 4" of lift and 1.5" spacer gets you 3". Also note that the rear tj106 spring is 4" & the tj104 is 3". This was a little confusing to me when i first started to gather info to do my lift! <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: 69442]
#866622
04/29/09 04:09 AM
you are right. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: BAZINGA]
#866623
04/29/09 04:13 AM
Thank you, that was driving me nutz!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
3" UPYOURKIA
[Re: DennisThompson]
#866624
05/07/09 01:34 AM
[Re: jaybur]
#866625
05/12/09 11:54 PM
Just wondering how you say that tj rear springs fit a kia sportage for a 3 inch lift in the rear. What year tj would work. Also does it mater size of engine.
[Re: budicexxx]
#866626
05/13/09 06:09 AM
only 97 and newer use the coil springs and any of them will work....not sure which ones use which springs but they have tag #s on them...the ones that end in 104 give you a 3" lift and the 106 give you a 4" lift...there are also 105's and pretty sure they will give 3 1/2"...if you find some just ask for a tag #, pretty sure the rubicons use a 106 if you want the 4" just ask for the rubicon springs and verify tag #s...as far as the shocks go pretty sure its any rav 4 rear shock, i can look @ work 2morrow for the specs,its been awhile and i know that the first time i looked there was only 1 option but then they changed it depending on 4 door or conv., i think...if you go with kyb the gr2s show 2 option but if you step up to the gas-a-just series (kg part #s), which are a lil stiffer than oe rav4s they only have 1 option....this will give you the extra travel needed, but you will have to put your original sleeves in the lower mounts or make some since they are a 5/8 hole and ours are a lil under 1/2"....the springs are the important part as that is what gives the lift, the shocks just give the travel you need for the extra lift..hope this helps <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: londart]
#866627
05/13/09 07:23 PM
Thanks alot. I think i found some 97 tj hardtop rear springs. I have to call him tonight. Now in search for the front spacers. Im gonna call for the shocks after as well. As for the springs not sure yet what the number thats on it yet. Hope all works out as i am really excited at putting a little lift on my 01 kia...LOL
