114
Topics138,177
Posts1,081,002
2002 Sportage - Fan Clutch
#880414
04/11/08 11:04 PM
Hello again!
I'm in need of assistance for a fan clutch replacement. After the $400+ dealer and local shop quotes, I figure this can't be all that hard, right? I hope.
Any helpful tips, steps, special tools I might need?
Thanks!!!
2002 Kia Sportage 4x4, stock. Yes, I'm boring. I'm looking to change that.
Re: 2002 Sportage - Fan Clutch
[Re: Kia_Bill]
#880415
04/12/08 05:31 AM
www.kiatechinfo.com or some of the guys here put in eletric fan they could give insight to that, can order a clutch for the fan with out blade from autozone
[Re: bombardj1]
#880416
04/12/08 02:41 PM
I still have my clutch and fan from when I switched over to an electric fan. If you are interested pm me. I really recommend putting on an electric fan though. I saw about 10% improvement in gas mileage when I switched.
[Re: Kia_Bill]
#880417
04/12/08 04:33 PM
be very carefull with the nuts, they round off super-easy.
[Re: Dave Scott]
#880418
04/12/08 07:04 PM
be very carefull with the nuts, they round off super-easy. 6 point socket FTW <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: Kia_Bill]
#880419
04/14/08 03:39 PM
Hey,that's perfect. Found the directions and even the part super cheap. Friggin mark ups.
I thought about the electric fan kit but it didn't look like a clean install and that part had me worried. I need it to run without remembering to switch it on and stuff and not run after the car is off.
[Re: Kia_Bill]
#880420
04/15/08 02:40 AM
Just put in a relay that is fed by a "hot with key on" so that it won't run when key is off. Actually, it is only a 2 cocktail job. I will be changing to a SPAL FAN-PWM when I get the 3-row radiator made and installed. Everet Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
