96
guests, and 4
Posts1,080,940
so i found these springs......
#898985
08/05/08 11:51 PM
so i was scrounging around my local junk yard, and i see a set of brand new coil springs sitting there, and im thinkin, those kinda look like i could run em under the kia for a little more lift. so i throw em in my pile of potential. the tag on them says the part number is 68004459aa and i cant find anything about them on the net. can anyone enlighten me?
cone filter, boche platinum 4 plugs, 235/75/15 kumho all terrains jeep tj rear springs and rav 4 rear shocks, rocksport gear 4" front springs, warn manual hubs, 2.25 inch exhaust, no cat, 48" thrush glasspack
Re: so i found these springs......
[Re: wyodriver4]
#898986
08/06/08 01:03 AM
You would have to know the make of vehicle they came off of to find what they are.
[Re: DennisThompson]
#898987
08/06/08 01:40 AM
459aa are springs from a Jeep XJ Grand Cherokee, fronts I believe as the xj has leafs in the rear!
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
[Re: Iron]
#898988
08/06/08 06:02 AM
The fronts will work if the struts operate properly (common sense)......
What are the specs???
We are rolling the dice without more info......
[Re: wyodriver4]
#898989
08/06/08 04:04 PM
What is their length and diameter? Post a picture of them. Please measure their spring rate too. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
