1 registered members (bill_bly_ca),
166
guests, and 3
Topics138,202
Posts1,081,251
Re: EURO, ***** & USA CAPS
[Re: justice]
#904337
09/14/08 04:43 PM
Someone correct me if I am wrong, but the best ratio you can get in a 3.5L gen II diff is 4.90 not 5.29 The 5.29 are gears that can be put in the gen I diffs.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
[Re: Scottie2113]
#904338
09/14/08 09:48 PM
Has anyone got the eu version to work?
I have the original version and have no problem.
What are the AE and BE in the euro version?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Scottie2113]
#904339
09/14/08 10:33 PM
Someone correct me if I am wrong, but the best ratio you can get in a 3.5L gen II diff is 4.90 not 5.29 The 5.29 are gears that can be put in the gen I diffs. The rumor is you can get Pt numbers for 5.29's for the 3.5 diffs through the euro caps.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: Tag]
#904340
09/14/08 11:46 PM
This is what I have found, after unzipping all of them:
USA: Run from \Wincaps\Caps.exe GEN: Run from \Wincaps\Caps.exe JPN: Run from \Caps.exe EUR: Run from \AE\Wincaps\Caps.exe (I could not get the same from \BE to run. Haven't tried to re-download original RAR.)
[Re: MontyMcV]
#904341
09/15/08 01:16 AM
I can get the programs to start. The problem is they do not offer any vehicles.
[Re: Tag]
#904342
09/15/08 02:14 AM
Their made to key in off of VIN. With the US one on the past, I have been able to tab past the VIN box and drill into the parts. If you have never used CAPS before, I suggest entering your own VIN into the US one and getting a feel for it. It is a bit of a clunky app.
[Re: MontyMcV]
#904343
09/15/08 02:33 AM
I have no problem with the US one and I do not use my vin.
I put in my model.
[Re: Tag]
#904344
09/15/08 03:25 AM
Yeah, I'm with you now. I can't get any of them to work with the lookup on model- including the USA one. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: justice]
#904345
09/15/08 04:57 AM
Someone correct me if I am wrong, but the best ratio you can get in a 3.5L gen II diff is 4.90 not 5.29 The 5.29 are gears that can be put in the gen I diffs. The rumor is you can get Pt numbers for 5.29's for the 3.5 diffs through the euro caps. I am not doubting you, but if you get these parts and they work, can you please let me know as I would want to upgrade mine as well. I put in 4.90s thinking they were the best I could get for my 3.5L gen II. Scottie
[Re: MontyMcV]
#904346
09/15/08 05:00 AM
USA: Run from \Wincaps\Caps.exe GEN: Run from \Wincaps\Caps.exe JPN: Run from \Caps.exe EUR: Run from \AE\Wincaps\Caps.exe (I could not get the same from \BE to run. Haven't tried to re-download original RAR.) Bill, I D/L them from your site and unzipped them. I looked thru all the folders and don't see an EXE file in them. Am I missing something? Do I use the EXE file from the current version of CAPS that I have to open it? <img src="/forums/images/graemlins/confused.gif" alt="" />
