86
guests, and 4
Topics138,274
Posts1,081,733
Re: differential lockers
[Re: DennisThompson]
#909305
10/20/08 08:17 PM
When I called Eaton back in March they still had the parts, but yes the "Spring and Clutch Rebuild Kit" for the Sportage was no longer in production. I asked if they could check to see if the parts were used in any other "Kits" and let me know so I could order that rebuild kit instead of using the old Sportage P/N. I also asked for pricing and they said only "Distributors" can get pricing. I have not heard from them since and have left a couple of messages.
[Re: logansportage]
#909306
02/03/09 05:46 AM
Dave,
How well did it work? Any info on that LSD would be great. Maybe I can find one locally that I can pull and drop into the front end.
Thanks.
Logansportage <img src="/forums/images/graemlins/patriot.gif" alt="" /> I'm the one who put the Miata Torsen into the front of my Sportage back in '04. It works great but I don't even notice it. The truck just goes where I point it with no jerking, no clunking, and no fuss. Much better in the ice and snow and mud than a regular LSD. For 4wd, it was an even bigger improvement than when I changed the rear open diff. to an LSD.
Ron Schroeder Long Island NY 99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD 00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress 73 Pinzgauer Swiss Army troop carrier
[Re: wd8cdh]
#909307
02/03/09 04:27 PM
Thanks for the info on the Miata diff. I spent several hours searching the forum about this fit. I'm going with a 89 RX-7 non-turbo lsd in the front. Got it for $50. I read on some Miata forums that it is a direct swap. Not as good as your Torsen, but a lot cheaper. Thanks for your input. Everet <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: logansportage]
#909308
02/08/09 02:32 AM
Everet, The web site was www.trackfinder.co.kr.Logansportage <img src="/forums/images/graemlins/patriot.gif" alt="" /> While browsing I tried the above link and it is now working and there is an english section on the locking diffs. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Dare to be different
'01 Long body, 40mm lift, AVM manual hubs, snorkel.
[Re: logansportage]
#909309
02/10/09 07:20 PM
I seem to remember several years ago that someone had installed a miata torsen type diff carrier on the rear of a 95 kia sportage (4wh dr of course). All that was necessary was to install my ring gear on the carrier and re-install and adjust.anyone remember this or can help me????
[Re: BigLar]
#909310
02/11/09 12:23 AM
Kia Moderator
I seem to remember several years ago that someone had installed a miata torsen type diff carrier on the rear of a 95 kia sportage (4wh dr of course). All that was necessary was to install my ring gear on the carrier and re-install and adjust.anyone remember this or can help me???? It was the front diff (7"). Try searching...
[Re: DamKia]
#909311
02/11/09 07:40 AM
there is thread on this subject else where........ i am having some lock-right style lockers made for the front and rear diff of my sportage.........
THE POWER TO SUPRISE.
