87 Gen1 Rebuild in Kansas
by Tuxedo_Ranch - 06/04/20 06:33 PM
97 4Runner too Old to Keep?
by brink - 06/03/20 06:10 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
by brink - 06/01/20 09:54 PM
'95 Montero 3.5L Coil Blowing
Hankook or Nitto?
2003 montero sport worth it?
by BC4x4 - 05/23/20 11:34 PM
0 registered members (), 103 guests, and 4 spiders.
Topics138,117
Posts1,080,630
Members15,064
squeaking sounds from front wheels.... any ideas??? #920561 12/14/08 12:59 PM
BiG_MoE Offline OP
i have just changed the bearings of both my front wheels yesterday n changed the 4x4 vacuum lines to thicker ones just in case but after i went out of the garage the tires are making a squeaking noise with or without the 4x4 engaged i thought it might be cuz the bearing just got changed so i cruised around in it for a while the sound goes away at high speed but at cruising speed its there and very noticeable.... i tried driving with the 4x4 engaged but it just made the sound way worst ... what could be the problem???
BiG MoE... Kia Sportage 2001, 2 door, convertable, 4 inch body lift, 2 inch suspension lift, 3000 watts pioneer sound system with 15 inch bazooka, K&N racing filter, 6000K Xenon HID Lights, exhaust system.
Re: squeaking sounds from front wheels.... any ideas??? [Re: BiG_MoE] #920562 12/14/08 07:41 PM
DennisThompson Offline
While you had it apart did you look at your brakes. Your ware indicaters could be making the squeak.
Re: squeaking sounds from front wheels.... any ideas??? [Re: DennisThompson] #920563 12/15/08 09:01 PM
logansportage Offline
Could be that you over tightened the bearings.
Re: squeaking sounds from front wheels.... any ideas??? [Re: BiG_MoE] #920564 12/20/08 12:02 PM
BiG_MoE Offline OP
nope the brake discs are brand new and the brake pads are as well so theyre definitly not the problem and the bearing as well isnt the problem their fixed properly
Re: squeaking sounds from front wheels.... any ideas??? [Re: BiG_MoE] #920565 12/20/08 12:12 PM
BiG_MoE Offline OP
UPDATE... problem solved the left wheels outer oil seal was the problem... althought it was brand new its diameter was 1mm off so it was touching the inner wheel axel making this squeacking noise i just had it replaced with my old one and the sound disappeared...
PHP: 7.2.31 Page Time: 0.025s Queries: 15 (0.007s) Memory: 2.8425 MB (Peak: 3.1637 MB) Data Comp: Off Server Time: 2020-06-05 00:08:58 UTC
