114
Topics138,177
Posts1,081,002
4x4 wont engage
#921314
12/17/08 04:57 PM
I have a 93 toy 4x4 V6 and the 4WD wont engage when the lever is pulled back. The green indicater light will not illuminate either, ideas please
Re: 4x4 wont engage
[Re: Adam F]
#921316
12/18/08 12:20 AM
If you have the ADD system, it could be a vacuum leak. My advice is to ditch the ADD, and throw on a set of manual hubs. Less wear on the front end, more MPG, and less to go wrong with the ADD crap. Just my 2cents.
93 4runner V6, 4.88's, 31" mt's with more to come. 03 Tundra V8 on 265's
Re: 4x4 wont engage
[Re: Billydkid]
#921317
12/18/08 12:41 AM
x2. w/ manual hub u can also go rwd in the low range too!
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 4x4 wont engage
[Re: allochris]
#921318
12/18/08 03:42 PM
It does have manual hubs. I have heard about a solenoid that may need to be replaced...ideas
Re: 4x4 wont engage
[Re: 5150]
#921319
12/19/08 01:59 AM
If it came factory with manual hubs, then you dont have ADD and that means no solenoids.
It has to be a mechanical problem. You have to get out there and troubleshoot.
Re: 4x4 wont engage
[Re: Adam F]
#921320
12/27/08 09:34 PM
I added manual hubs and it had ADD from the factory.
Re: 4x4 wont engage
[Re: 5150]
#921321
12/28/08 12:43 AM
Try this out....http://www.4x4wire.com/toyota/tech/add/
Re: 4x4 wont engage
[Re: allochris]
#921322
01/09/09 03:34 AM
x2. w/ manual hub u can also go rwd in the low range too! which is funner than heck don't ya know... <img src="/forums/images/graemlins/smile.gif" alt="" />
canyon country explorer 1993 4x PUP
