89 GEN1 LWB Headlight Washer Pump Rebuild
by chadzeilenga. 06/24/18 06:13 AM
1989 LWB A/T Temp Light
by chadzeilenga. 06/24/18 05:36 AM
GEN1 LWB Radio reception
by chadzeilenga. 06/24/18 05:34 AM
by rascott. 06/20/18 12:47 PM
Bumper?
by TOASTY. 06/20/18 02:59 AM
Instrument Cluster Fuse
by rxinhed. 06/17/18 04:50 PM
Winch bumper
Gen 2 seat options
My '88
4x4Wire YJ
0 registered members (), 92 guests, and 3 spiders.
Topics137,876
Posts1,079,486
Members14,783
Page 2 of 3 1 2 3
Re: Pre 3.4 Swap Questions [Re: yotaman7] #921537
12/23/08 05:40 AM
12/23/08 05:40 AM
kewlynx  Offline
Fairbanks, Alaska *****
FSM = factory service manual.
**ubi apis- ibi salus**
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921538
12/23/08 05:46 AM
12/23/08 05:46 AM
yotaman7  Offline OP
N. KY
I got that, I was refering to the EWD's from www.techinfo.toyota.com
Just wondering if people were satisfied with these diagrams. Thanks
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Pre 3.4 Swap Questions [Re: yotaman7] #921539
12/23/08 07:04 AM
12/23/08 07:04 AM
kewlynx  Offline
Yep, have them for my Runner and the roomdawg's Corolla.
Beats the dogsnot out of paying $120 or more. Once I downloaded stuff and organized it, put a copy on a jump drive. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Give the TSB's a cursory look too, so you can make sure if there were any modifications along the way that you can incorporate them into your efforts. Just a thought.
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921540
12/23/08 02:41 PM
12/23/08 02:41 PM
G
Greg_Canada  Offline
Toronto, Canada
NO you cant, in 99' toyota started using an AFR sensor and not o2 sensors.
Also, the Throttle body changed from a 3-wire to 5-wire somewhere in those years.
Also, the MAF's are different from before and after 99'.
ALso, pre-00 taco's had EGR.
So basically, when you get the harness, you have to get all the sensors from it. You can get a 96-04 harness, but you have to get EVERY sensor with it to make it work right, and just use what you have now as a long block.
Good luck.
89 4Runner
Re: Pre 3.4 Swap Questions [Re: Greg_Canada] #921541
12/24/08 04:20 AM
12/24/08 04:20 AM
kewlynx  Offline
That's cool. FWIW, my '99 4R still has its 02 sensors, but is a 2.7 mill.
As we'd mentioned in the swap article, the more complete the donor, the better off you'll be. That said, if you find a good donor, make DANG SURE you get the VIN while you're pulling parts to make your reverse parts research goes a little easier. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921542
12/24/08 05:11 AM
12/24/08 05:11 AM
CJM  Offline
Penticton BC
My 00 4runner 3.4L has 2 O2's ....
86 4x4 , fiberglass bed , 1/2 doors , hood, etc..
83 Trekker SR5
NEW Trekker forum
Re: Pre 3.4 Swap Questions [Re: CJM] #921543
12/24/08 06:48 AM
12/24/08 06:48 AM
G
Greg_Canada  Offline
Toronto, Canada
NO, you guys don't know what i mean.
They look the same physically, but mechanically, the pre-99 uses an o2 sensor (narrow band) where the 99 and up uses an AFR sensor (wide band).
Basically, the AFR sensor is more accurate.
An o2 sensor is most accurate when closest to 14.7:1 (stoich) but the afr sensor is more accurate than the o2 sensor when it's heading away from stoich (say 12 or 13:1) thus making the two systems uncompatible (as well as the computers).
89 4Runner
Re: Pre 3.4 Swap Questions [Re: Greg_Canada] #921544
12/24/08 06:56 AM
12/24/08 06:56 AM
kewlynx  Offline
So which one would be the AFR if it's in the same place as the 02 sensors? Got a reference? That would be a good read.
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921545
12/24/08 07:03 AM
12/24/08 07:03 AM
G
Greg_Canada  Offline
Toronto, Canada
Pre-cat is def AFR.
I'm not sure of the 2.7, but the 3.4 def. used this.
Lets see if i can dig up the info (got it from Gadget @ URD)
OK here is some random info about the differences
http://hhogear.com/index.php?page=what-do-i-need-to-know-about-my-oxygen-sensor
Ok here is a little explanation from gadget
http://www.customtacos.com/forum/showthread.php?p=569960 (read from post #7 and down)
So yeah, might be all yota's 99 and newer with AFR's... dunno 100% tho...
89 4Runner
Re: Pre 3.4 Swap Questions [Re: Greg_Canada] #921546
12/24/08 07:13 AM
12/24/08 07:13 AM
kewlynx  Offline
I did see that URD has an AFR calibrator on their site, so that's rather interesting. Another site where I see these being discussed is www.fuel-saver.org
I just picked up an Actron OBDII tester last weekend; might fire up the CD and see if there are any code trees for the AFR vs 02, or both.
Thanks for the linkys. Never hurts to have that stuff around. I've still got a lot to learn with these new gen mills! <img src="/forums/images/graemlins/baby.gif" alt="" />
Sorry if we're goin' a little off track, Yotaman!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 2 of 3 1 2 3
Page Time: 0.010s Queries: 16 (0.004s) Memory: 1.0649 MB (Peak: 1.2005 MB) Zlib disabled. Server Time: 2018-06-24 12:34:06 UTC
