monty build thread
by motero - 01/24/22 03:29 PM
Reloading - My Observations
Water temperature sensor
Early Gen I trim levels
Happy Holidays
Topics138,256
Posts1,081,621
Members15,240
4wd differential #928915 02/02/09 06:30 AM
toyT100 Offline OP
Is servicing the 4wd as easy as just drain and refill?
Re: 4wd differential [Re: toyT100] #928916 02/02/09 06:51 AM
4
4xGeek Offline
Servicing the transfer case is a simple drain & fill... Just always make sure you can get the fill port off before you drain! <img src="/forums/images/graemlins/shiner.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: 4wd differential [Re: 4xGeek] #928917 02/03/09 05:01 AM
toyT100 Offline OP
where can i find the amount of fluid needed and type of fluid n that stuff...is it in the owner's manual.
Re: 4wd differential [Re: toyT100] #928918 02/03/09 05:18 AM
ErikB Offline
Toyota Moderator
yep!
http://home.4x4wire.com/erik
Re: 4wd differential [Re: ErikB] #928919 02/09/09 11:21 PM
toyT100 Offline OP
how are the front and rear differentials?
Re: 4wd differential [Re: ErikB] #928920 02/13/09 11:24 PM
toyT100 Offline OP
has anyone done the drain and refill for t case and both diffs.--jus wondering how it is
Re: 4wd differential [Re: toyT100] #928921 02/14/09 03:42 AM
E
eleet Offline
What advice do you need about this procedure?
It's pretty straightforward. Remove the fill plug then drain plug. Replace crush washers if there are any. Replace and torque drain plug. Add oil until it's full. Replace and torque fill plug.
It is easiest to use a pump with one hose, not two, like this:
http://www.thetoolwarehouse.net/shop/LNC-615.html
97 T100 4x4
97 328i
95 540i restoration project
Re: 4wd differential [Re: eleet] #928922 03/09/09 02:02 AM
toyT100 Offline OP
the transfer case calls for 1.2 quarts....how can i check to make sure the fluid level isnt too low or too high after i re-fill it?
Re: 4wd differential [Re: toyT100] #928923 03/09/09 04:02 PM
ErikB Offline
Toyota Moderator
You fill it until it starts draining out the fill plug just like the diffs.
Re: 4wd differential [Re: ErikB] #928924 03/10/09 12:19 AM
toyT100 Offline OP
I first decided to change the fluid in the transfer case bc i was starting to hear a noise coming from the transfer case when accelerating. I just changed it today and that def helped, but the noise is still there,jus not as bad. Any suggestions?
PHP: 7.2.34 Page Time: 0.032s Queries: 16 (0.010s) Memory: 2.8839 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2022-01-24 20:19:32 UTC
