97
Posts1,080,940
CEL code N/A ? Is this a dealer specific code?
#937959
03/30/09 01:38 AM
I've got a code reader I bought at Harbor Freight and it works pretty good, however I've had a code come up and when I check the code it comes back with a code N/A. Do I need a better code reader (maybe stop at Autozone) or do I have to go the dealer and have them overcharge me to read the code?
Re: CEL code N/A ? Is this a dealer specific code?
[Re: homerdog]
#937960
03/30/09 02:02 AM
what was the code # ? or did the code reader say no code ? is the check engine light on ?
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#937961
03/30/09 06:03 PM
yes, the CEL light is and the reader says code N/A
[Re: homerdog]
#937962
03/31/09 05:54 AM
do you have a advance auto near you or auto zone, they will check it for you,
[Re: bombardj1]
#937963
04/07/09 12:21 PM
I took it to Autozone and it came back with a P013A code? Say's it has something to do with fuel/air metering. Any ideas?
[Re: homerdog]
#937964
04/07/09 12:29 PM
okay, I found this, where do I find a copy of the actual service bulletin?
Make : KIA Model : SPORTAGE Year : 2002 Manufacturer : KIA MOTORS AMERICA, INC. Service Bulletin Num : 51 Date of Bulletin: JAN 01, 2002 NHTSA Item Number: 629973 Component: ELECTRICAL SYSTEM:IGNITION:MODULE Summary: SUBJECT REGARDING REPORTS OF DIAGNOSTIC TROUBLE CODES P013A OR P013 BEING STORED.
[Re: homerdog]
#937965
04/07/09 01:46 PM
kiatechinfo says it a short between front O2 sensor and the ecm. but they have the P013 with out the A
[Re: bombardj1]
#937966
04/07/09 06:21 PM
kiatechinfo says it a short between front O2 sensor and the ecm. but they have the P013 with out the A ok, thanks, looks like what Autozone showed me is just the generic sub-system message. I'll have to check and see if I've got a wire rubbing on something.
[Re: homerdog]
#937967
04/07/09 07:17 PM
go to www.kiatechinfo.com sign up if you have not used it before, after you put in all ifo. on your kia type in P013 it will tell you about it,
[Re: bombardj1]
#937968
04/07/09 08:08 PM
go to www.kiatechinfo.com sign up if you have not used it before, after you put in all ifo. on your kia type in P013 it will tell you about it, I haven't had much luck getting anywhere on that site. I can log in but that's about it, I can't ever find anything.
