100
Topics138,180
Posts1,081,013
Re: 2.3L Stroker info post
[Re: k120189]
#938158
04/04/09 04:22 PM
This is all very interesting,but a little bit complicated for me. I would certainly install larger injectors and larger throttle body along with a more efficiant exhaust system. Any ideas on the injectors and throttle body would be welcome.
[Re: sportedge]
#938159
04/07/09 02:49 PM
any injector of the same style and plug would work..might have to make a reference sheet for that
and i have seen people using mustang tb's but im not sure if its v6 or v8 have to look into that as well. if u find something before i do please post it
[Re: k120189]
#938160
04/08/09 12:35 AM
i am pretty sure the mustang tb's are being used with the fwd intake manifolds though. not too sure if it would work with our intake manifolds or not. as it is designed to come back over the top of the engine.
[Re: DEFBOY35]
#938161
04/08/09 02:03 PM
anything could be done..im gonna try and find a bigger tb and figure out how to mount it. and re route the intake away from the exhaust mani
[Re: k120189]
#938162
04/09/09 05:40 AM
the problem with using the fwd intake manifolds is that it would have the tb aimed directly at the firewall with very little room to have a good intake set up.
the other thing to keep in mind is that they went to the mustang tb because the stock fwd is a single tb, dont remember the sizes off hand, were as we use a dual tb.
and i do remember reading that the dual set up, although each one is smaller added together flows more air. not sure if that was more or not than the mustang tb though.
[Re: DEFBOY35]
#938163
04/09/09 03:40 PM
we have a two piece intake on our motors i was almost thinking of fabbing a custom upper portion just a box like thing that bolts to it and has a forward facing tb..it cant be too bad...then again i have cnc machines at my disposal. i'll draw something up in solidworks later and post up my idea
[Re: k120189]
#938164
04/09/09 04:25 PM
Kia Moderator
Maybe try to get it to turn around and have the air filter on the inlet side of the motor rather than over the hot exhaust. Carbon canister can be moved a bit further back to make room, and the front hub vacuum solenoid et al can be stripped out.
[Re: DamKia]
#938165
04/16/09 07:16 AM
Piston wise I found this.... it has also a US branch.. http://www.flatlander-ipp.nl/hpkits/pek-kia.shtml
[Re: fokion]
#938166
04/16/09 03:48 PM
good stock replacements. but to stroke it you need pistons with a lower deck hight thats why sr20 pistons are used because at tdc the piston is 1mm or so below deck.
and for those that dont know what decking is its when the pistons at top dead center are even with the top of the block
i think using stock pistons with the f2 crank it over decks by like an inch. in a few weeks im going to get my kia engine i hope.
