1 registered members (Bigshankhank),
277
Topics138,074
Posts1,080,447
Members14,971
Most Online581 Apr 3rd, 2017
Re: 2.3L Stroker info post
[Re: k120189]
#938167
04/22/09 04:56 AM
Do you have to over bore for the SR20 pistons? If so how much? Do you have part #s for the pistons that work? When I find a piston that I know works then I will get the Probe flywheel modified for the Kia crank postion sensor.
[Re: DennisThompson]
#938168
04/22/09 05:41 AM
Stock is 86mm I believe so yes you would have to. Also need to machine room for stock rod. Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Everet]
#938169
04/22/09 02:07 PM
stock bore for sr20 is 86mm so u only have to over bore if u want to. get u a part number in a bit
[Re: k120189]
#938170
04/29/09 02:20 PM
thru http://importperformanceparts.net/the part number for sr20de pistons with rings is PAD30 $36 a peice $144 for four you can order std .020 and .040 over
[Re: k120189]
#938171
04/30/09 07:46 AM
Found also that if it is any help.. They have a US branch too.. http://www.flatlander-ipp.nl/hpkits/pek-kia.shtml
[Re: fokion]
#938172
04/30/09 02:11 PM
yea they are actualy a part of import performance parts good link tho if anyone can find a better deal then 144+ship for the sr20 pistons let me know
[Re: k120189]
#938173
05/01/09 02:34 AM
I was thinking of going back stock but I think this just changed my mind. Thanks for the info.
Re: 2.3L Stroker info post *DELETED*
#938174
05/02/09 02:22 AM
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
[Re: 5jackz]
#938175
05/02/09 02:47 PM
can the post above me be deleted not to be an ass or anyhting but it has nothing to do with this thread.
dennis if u have any more questions ask em and i will look it up.
theres something about using rx7 injectors for more fuel if i find it again i'll post it
[Re: k120189]
#938176
05/02/09 11:25 PM
if i remember correctly, using the sr20 pistons will lower the compression quite a bit, which is fine if you will be using them in a boosted application. but if you are sticking to NA then it may not be the best option
