4D56 Oil Filter woes...
by bill_bly_ca - 07/04/22 11:24 PM
by - 04/16/06 12:58 AM
0 registered members (), 79 guests, and 0 spiders.
Topics138,276
Posts1,081,746
Rating: 1
Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: 2.3L Stroker info post [Re: k120189] #938167 04/22/09 04:56 AM
DennisThompson Offline
Do you have to over bore for the SR20 pistons? If so how much? Do you have part #s for the pistons that work? When I find a piston that I know works then I will get the Probe flywheel modified for the Kia crank postion sensor.
Re: 2.3L Stroker info post [Re: DennisThompson] #938168 04/22/09 05:41 AM
Stock is 86mm I believe so yes you would have to. Also need to machine room for stock rod.
Re: 2.3L Stroker info post [Re: Everet] #938169 04/22/09 02:07 PM
k120189 Offline OP
stock bore for sr20 is 86mm so u only have to over bore if u want to. get u a part number in a bit
Re: 2.3L Stroker info post [Re: k120189] #938170 04/29/09 02:20 PM
k120189 Offline OP
thru http://importperformanceparts.net/
the part number for sr20de pistons with rings is PAD30
$36 a peice
$144 for four
you can order std .020 and .040 over
Re: 2.3L Stroker info post [Re: k120189] #938171 04/30/09 07:46 AM
fokion Offline
Found also that if it is any help..
They have a US branch too..
http://www.flatlander-ipp.nl/hpkits/pek-kia.shtml
Re: 2.3L Stroker info post [Re: fokion] #938172 04/30/09 02:11 PM
k120189 Offline OP
yea they are actualy a part of import performance parts
good link tho
if anyone can find a better deal then 144+ship for the sr20 pistons let me know
Re: 2.3L Stroker info post [Re: k120189] #938173 05/01/09 02:34 AM
I was thinking of going back stock but I think this just changed my mind. Thanks for the info.
Re: 2.3L Stroker info post *DELETED* [Re: DennisThompson] #938174 05/02/09 02:22 AM
5
5jackz Offline
Post deleted by DamKia
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: 2.3L Stroker info post [Re: 5jackz] #938175 05/02/09 02:47 PM
k120189 Offline OP
can the post above me be deleted not to be an ass or anyhting but it has nothing to do with this thread.
dennis if u have any more questions ask em and i will look it up.
theres something about using rx7 injectors for more fuel if i find it again i'll post it
Re: 2.3L Stroker info post [Re: k120189] #938176 05/02/09 11:25 PM
DEFBOY35 Offline
if i remember correctly, using the sr20 pistons will lower the compression quite a bit, which is fine if you will be using them in a boosted application. but if you are sticking to NA then it may not be the best option
PHP: 7.4.30 Page Time: 0.035s Queries: 16 (0.013s) Memory: 2.9269 MB (Peak: 3.1928 MB) Data Comp: Off Server Time: 2022-07-06 03:45:53 UTC
