89 GEN1 LWB Headlight Washer Pump Rebuild
by chadzeilenga. 06/24/18 06:13 AM
1989 LWB A/T Temp Light
by chadzeilenga. 06/24/18 05:36 AM
GEN1 LWB Radio reception
by chadzeilenga. 06/24/18 05:34 AM
by rascott. 06/20/18 12:47 PM
Bumper?
by TOASTY. 06/20/18 02:59 AM
Instrument Cluster Fuse
by rxinhed. 06/17/18 04:50 PM
Winch bumper
Gen 2 seat options
My '88
4x4Wire YJ
1 registered members (Loosecat), 98 guests, and 5 spiders.
Topics137,876
Posts1,079,486
Members14,783
Rating: 1
Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: 2.3L Stroker info post [Re: DennisThompson] #938187
05/13/09 02:16 PM
05/13/09 02:16 PM
k120189  Offline OP
Lenox,MA
fokion those are the vehicles that have the crank you need to stroke the motor
Re: 2.3L Stroker info post [Re: k120189] #938188
05/13/09 06:16 PM
05/13/09 06:16 PM
fokion  Offline
Athens Greece
Ah Ok....
are all these cranks the same??? ( looks like it might....)
Re: 2.3L Stroker info post [Re: fokion] #938189
05/14/09 01:31 PM
05/14/09 01:31 PM
k120189  Offline OP
Lenox,MA
i belive they stroke it the same
the r2 crank is forged and requires some work like stuff for the oil pump but i believe it uses out flywheel so it has its ups and downs
the f2 drops in and works with our oil pump but has a different flywheel bolt pattern i believe the flywheel from a mazda b2200 will work as out flywheel is used on our engine when swapped into that truck
Re: 2.3L Stroker info post [Re: k120189] #938190
05/14/09 03:10 PM
05/14/09 03:10 PM
fokion  Offline
Athens Greece
Got it thank you
is sounds like the F2 crank is more suitable overall
Re: 2.3L Stroker info post [Re: k120189] #938191
05/15/09 12:41 AM
05/15/09 12:41 AM
DEFBOY35  Offline
Alberta, Canada
keep in mind the r2 crank was never available on the north american market and is very difficult to come across, i have been trying to contact overseas wreckers and vendors with no luck at all.
as the forget crank will take more power, as well being able to use the stock flywheel would be nice.
hopefully the b2200 flyweel would fit into the sporty, but i am not sure if it would match up to our transmission, perhaps that is why it works for the b2200's.
Re: 2.3L Stroker info post [Re: DEFBOY35] #938192
05/15/09 12:58 AM
05/15/09 12:58 AM
k120189  Offline OP
Lenox,MA
deffboy the Mazda b-series folks (used to be one myself) drop the Sportage engine in the 2200 all time and use the stock tranny with our flywheel and clutch so if our flywheel and clutch fit on their tranny i don't see why the opposite wouldn't be true in fact i think the mazda b-series clutch fits our flywheel as well so we can use our stock clutches on the b-series flywheel. i need some money to get the ball rollin i would love to be talking from experience and not just close to a year of reading
Re: 2.3L Stroker info post [Re: k120189] #938193
05/15/09 03:34 AM
05/15/09 03:34 AM
DennisThompson  Offline
Utah
To use the F2 flywheel on the Sportage you need to have the crank position ring removed from the Kia flywheel, have the F2 flywheel machined and have the crank position pressed on. Other than that they look identical.
Here is a pic of the two side by side.
Re: 2.3L Stroker info post [Re: DennisThompson] #938194
05/15/09 05:08 AM
05/15/09 05:08 AM
Everet  Offline
Silicon Valley, CA
Dennis,
Is the gear pressed on the sportage or welded?
Is there weight the same?
Re: 2.3L Stroker info post [Re: Everet] #938195
05/15/09 09:25 PM
05/15/09 09:25 PM
Utah
The crank position ring looks pressed on, I don't see any welds. As far as the weight I'm not sure I will check when I get a chance.
Re: 2.3L Stroker info post [Re: DennisThompson] #938196
05/16/09 06:51 AM
05/16/09 06:51 AM
fokion  Offline
Athens Greece
I lost you on something
since the F2 crank is going to be used why you dont use also the F2 flyweel???
Moderated by  Axe Man, DamKia
Page Time: 0.012s Queries: 16 (0.004s) Memory: 1.0722 MB (Peak: 1.2068 MB) Zlib disabled. Server Time: 2018-06-24 08:49:11 UTC
